Engine Removal with the Hood On
I personally don't see not removing the hood as cutting corners. There is just as much chance of screwing up your hood taking it off. For example, scratching it, dropping it, setting it down too hard, having a kid or pet scratch it, etc.
DC3 (08-17-2021)
I vote remove the hood. It's easy. i do mine myself. i take one of the bolts out of the hood on the pass side and replace it with a 2" piece of threaded stud then remove the other bolt. then i go on the drivers side and hold the front of the hood with my left hand and remove both bolts from the hood and then remove the hood. make sure you trace the outline of the hinge for reassembly. Or just get someone to help. As far as storing the hood throw a blanket or two on the roof of the car and set it on the roof if you don't have anyone running around who can bang into it. in the picture you can see my original hood setting on the roof while i was test fitting a L88 hood a few years ago.
leaving the hood on is asking for grief and trouble. before you remove it take a silver sharpie and mark the front hinges on the frame and the hood. That way re-alignment is as easy as getting it in the spot that is marked. Just get a friend or neighbor to help tieh removal. I use a gantry i built and wrap strapes around it aot get it off by myself. Get a bicycle wall hanger and pad it then put the hood on it nose down. It will self center then I use ratchet straps and hook them inot th epin holes and secure them to the wall or ceiling....
FWIW, I did something like this except I used blue painter's tape along the hinges' edges. I didn't want to leave permanent marks on the hood. I've done this several times with 100% success.
BTW and also FWIW, I wouldn't dream of pulling the engine with the hood on. You already have challenges, making sure to get it out without damaging anything. Why add more risk?
Good to hear some here have tried it successfully. I think it is doable and the only reason I can think of that I would want the hood off is if I had a big enough cherry picker to grab from the front. But since I most likely have to pull from the side, removing the hood has so much less benefit.
Received 3,220 Likes
JUST PULL THE HOOD. You're considering the job of pulling the engine (a much more involved job), and trying to cut a corner here? Don't make it hard on yourself, or have to worry about smacking the hood with the engine in the process. It's slightly awkward but not that heavy. Use a sling and your engine puller to remove it first if you have to. You'll be glad you did in the long run.
The following 2 users liked this post by Richard454:
Bikespace (08-19-2021),
Jarhead 74 Vette (08-18-2021)
I had no choice. I literally had no one to help me with this project. Trying to find a way to remove the hood by myself and then store it safely for the duration of the project was a greater risk to the hood than pulling the engine with it on. Plus it would have taken way more of my time. Pulling the engine with the hood on was easy and I'd do it again without reservation.
DC
JMO ... Kinda like serious work under the dash without first removing the seat. YMMV
JayK47 (08-18-2021)
69L88 (08-18-2021)
#34
I'll be sure to post pictures when it comes time to pull the engine. If I decide to pull the hood, I'll ask 69L88 to drop by for the assist.
#36
I did mine with the hood. It didn't occur to me at all that I'd needed to remove it at any point in the removal of my 350 or installation of my 400. I've done plenty of jobs where I didn't do something to save time and spent more time working around the thing - the engine swap was NOT that job.
If you're pulling the motor AND the transmission, then yes, yank the hood.
#37
Thank You! But don't You All agree that this 68 sb hood Vette is really fast?? I have seen videos of other heavily modified C3's with Huge tall hood scoops going down the even the shorter 1/8 mile track that didnt seem nearly this quick! I would love to know what is underneath that low hood. I have a low hood myself, thats why...
#38
I've never counted the number of vette motor changes that I have helped with. you just go in from the side. Another thing is I make non removable cross members removable unless the owner has something about pure stock numbers matching idea. I never do the engine and tranny connected. I put the engine in and then stab the tranny to the mounted motor with a floor jack or stands if on a lift to adjust the rear of the motor down.
We tracked the man hours of changing motors different ways and it saved time and money doing them separated with the hood left on! Two people was always less than a days job especially with race type motors with very little garbage under the hood. At the race track we had motor changes down to an evening before heading back to the hotels
