Original engine?
Compare the numbers on he engine block (passenger side below valve cover) and the VIN Number located on the “A” Pillar. Just Google C3 Corvette matching numbers and VIN, The numbers and letters of the VIN also give details about the car.
A pillar VIN
Engine number location
A pillar VIN
Your VIN and engine stamp pad agree and look to be original. However, both are for a 1973 car. And you think you have a '71 C3? Does it have a rubber front bumper or a chrome front bumper? If it is chrome, a prior owner has tried to make a '73 car into a "chrome bumper" car.
Just another Corvette guy
That's because Eli's car is a '73.
'73and'75 (08-14-2021)
Lots of code tools are located here. Be sure to look for the trim tag in the driver side doorframe.
http://corvettec3.ca/
Greg...
So why did the OP put "(71)" in his intitial post???? But, thanks for your 'kind' reply.
Location: Loud, Raw and Dangerous 1968 327 4S in Southern California
The answer for the 71 OP (poster #1) is it looks like it could be original but does have some modification (like headers). As mentioned by poster #2 and his 73 pictures, the VIN and engine code match is the way to check further. Got my laugh for the day...thanks guys!
interpon (08-14-2021)
Replaced parts or missing that can be seen.
Master cylinder.
Water pump.
Upper Radiator Hose.
Radiator.
Radiator Cap
Ignition Wires and cap
Valve covers
Wiper door actuator boot
Unusual bracket on passenger hood latch
Lower ignition shielding and spark plug heat shields
Alternator
As stated exhaust manifolds
Master cylinder.
Water pump.
Radiator.
Radiator Cap
Valve covers
Alternator
The following 2 users liked this post by Greg:
BKbroiler (08-14-2021),
Catfish4818 (08-14-2021)
