"Better" and "Best" brake caliper upgrades?
Running stock rims and rotors is there a "better than OEM" brake caliper and also a "lots more money but really worth it" brake caliper?
Or do you have to go to a larger wheel and a larger rotor to realize significantly improved braking?
Next step up from stock calipers are Wilwood aluminum bolt-in replacements, you wont improve braking much but are substantially lighter and less prone to leaking.
also, make sure to spend some time searching in this forum as this topic is discussed a lot.
Received 5,595 Likes
The stock brakes are very capable when properly set up and usually problem free, although you will hear many stories of leaks and problems (I won’t go there).
To answer your question, the “best” improvement requires larger rotors that then provide better braking leverage but also larger diameter wheels. If you want to keep your current wheels and improve braking (the better vs. best option), ensure all your calipers are sound, there are no leaks, you have a firm pedal, the rotors are true and you have fresh brake fluid. Then look at upgraded brake pads that offer the characteristics you consider important. These include depending on your perspective - fade resistance, faster stopping, low wear, low dust, cold vs. hot performance and remember that it is always a trade off, you can’t have all of these things!
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Keep your stock calipers. They do a great job already. Unless you're going to spend time and money reducing vehicle weight or adding stickier tires, the expensive bling brakes won't stop your car any quicker than what you've got now.
Peterbuilt (04-16-2021)
When I reconditioned the entire suspension on my vette, I went with the best rubber bushing front OEM replacement suspension kit I could get. It may have been from Vette Brakes (out of business). It was a TRW kit. High quality. I then moved to the rear trailing arm assembles (Van Steel rebuilt), half shafts (Van Steel) and poly adjustable strut rods (VB&P). Also, fresh tires and good KYB gas charged shock absorbers. I found that with all this, I had no worries and the car handled GREAT. I still have the gymkana rear spring and (original) front coil springs.
Unless your needing to stop or brake in some fashion other than normal driving than the stock brakes work just fine. I use off the shelf remans and never had a problem.
Stainless steel ORinged stock brakes. Even with new stainless lines, braided steel, 600 degree motul fluid, the best carbon metallic pads.
At some point over 100 mph they'll not even slow you down.
At some point after repeated braking you end up with a severe pucker factor
Just be careful, if you spend the money to get racing this, and racing that, high temp racing pads, ETC, and then putts around town, you wont be happy.
Running stock rims and rotors, nothing will stop you any quicker. I have 42 year old OEM calipers on one of my 78’s and they stop as well as the Wilwoods I put on the other 78. The difference is felt in cornering over bumps, as the aluminum calipers save weight right were it counts. But, I love going around curves very fast, so the car with the Wilwoods also got the suspension lowered and stiffened. Depends on your driving style. Minor changes to the brakes won’t make nearly the difference as minor changes with the suspension and tires.
brassplyer (04-17-2021)
I actually don't have any particular complaints about the stock brakes at this point but wondered what else there is and whether it's worth upgrading.
Dementer sole survivor
Received 6,341 Likes
2016 C3 of Year Finalist
I raced my car a little and the organic pads turned into a brick after they cooled down. Avoid those. THe best things I ever did was to
https://www.hawkperformance.com/compounds/street
https://www.hawkperformance.com/street
these are the corvette models
https://www.hawkperformance.com/part...el=80862¬e=
- replace the original lip seals, about $80 for the parts an da days worth of labor and caliper paint.
- use Hawk pads. I grabbed the blue pads. they are dusty but they grab like a rottweiler on a bad mans leg. Do a litle research on different pads and you will be super happy.
- Make sure that if you ever replace your master cylinder that its for 4 wheel disc brakes and that it matches your application whether its maunal or power. Many issues here on people getting the wrong parts
The following 2 users liked this post by Rescue Rogers:
Bikespace (04-17-2021),
Old Pro Solo Guy
The rather expensive ($100) Hawk and Carbotech and Performance Friction pads really do stop better. They grab like 20-25% stronger, plus they can get much hotter than stock ones before they fade. They work pretty good cold on the street too. They are not race pads. I would call them high performance street pads or autocross pads. You will have to get the rotors almost red hot before they'll fade, IIRC over 1000 degrees.
This is one case where you really do get what you pay for.
Pretty good,,, on the street isn't what most people are looking for. 90% of people just drive normal street driving without getting there pads hot. I found that a normal organic or semi metallic work the best. I have a set of Hawk HPS pads and took them off.
Old Pro Solo Guy
So I ran similar to those on my 70 Z28 and loved them.
What did you not like about them on a 4 wheel disc Vette?
Dusty?
Cold temps?
etc...
Dusty?
Cold temps?
etc...
The only thing I dislike about the blue Hawk pads is the dust. Cold braking is ok , just normal driving they warm up and they wear like iron. T
Rescue Rogers (04-21-2021)
Old Pro Solo Guy
Yes those kinds of pads can get kind of testy below 35 degrees. Sometimes even a little warmer.
Then there is the dust! Ugh!
I had some auotocross special extra high friction pads back in the day. Worked GREAT.... stopped like a boat anchor.......BUT the DUST!!
Turned my wheels solid BLACK in 2 DAYS!
