Which new heads to go with?
#41
That's a casting number. What you want is the number from the number pad on the right side of the motor.
All that number tells you is this:14016379 Small Block V8 1977-1979 350, 2 bolt or 4 bolt
https://www.chevyhardcore.com/news/r...sting-numbers/
#42
When you say the number pad on the right side on the motor, is that the pad near the front of the heads on the right? If so, this block does not have it and I researched it and found a few posts of others with the same block and no number pad.
#43
Received 3,043 Likes
St. Jude Donor '05
One plus of the Dart brand is they usually have plenty of material for the guy that wants to port them.
WHy their sizing can be way off is beyond me. Mine were 15cc larger than advertised.
Thier latest head, which the chinese heads are copies of are pretty decent.
#44
Dr. Detroit
Received 3,893 Likes
Hard to say for a die hard Dart guy I bet. Good to hear someone else echo my opinion on those SHP's though.
Seems to me that brand loyalty will always meet with disappointment eventually . Got to go with what is good regardless of the brand. However a good known brand has a better chance of success vs an unknown one or one that is known to be of questionable quality.
When they invited me over to look at the new Wet Flow Pro-1 heads in 07.......I was impressed. The heads made 20 more horspower and torque over the previous series and there was zero increases in flow.....(well, the low lift number were a little better...). I bolted my first set on a 37' Business Coupe along with a 292H Magnum Cam, two 450 Holley's on a Weiand Tunnel ram on a bone stock 1969 350 short block and that car was silly......easy 12 second car.....3000 converter and 3.73 gears.
So I have spec'd Dart heads for these engines for a long time......BUT, when the SHP came out, I ordered a pair direct from Dart and had them shipped to Texas.....
Generally I order heads assembled and pull them apart after I get them.....I really don't trust anyone. I am not sure who assembled these SHP heads but the guides were too tight and the installed heights were all over the place which means the valve job was suspect....so they went back and I had the customer pop for Pro 1's for an extra $300.....I ordered these un-assembled and they were perfect. I am not sure what they are doing up there but I am sure one way they are saving money is the help.....
Oh well.....soon here I will be taking apart a pair of the new Trick Flow 175cc "Double Hump" heads....I will report my findings in a build thread.....stay tuned.
Jebby
#45
Dr. Detroit
Pull a valve cover.....L-82 had guide plates, L-48 did not......if it doesn't, then it is safe to assume it is a low-po 180 horse or so unit with cast dish pistons.
Jebby
#46
Received 2,144 Likes
Or could be a L48 w/ L82 heads.
I think the O.P. means, there is not any numbers on the pad. Which almost always indicates the block has been decked.
Who knows?
Who knows?
#47
St. Jude Donor '05
Who knows what coulda happened to an engine over this many yrs? In the long run does it matter that much?
#48
Well just gonna have to pull the heads when your ready. Dish pistons =L-48 flat top pistons =L-82.
if your lucky that is. As cv67 says since it appears it’s not even a stock block anything could have been done.
in either case flat top pistons are much better than the dish and can give you a true quench zone. The open dish pistons have no actual squish pad. D-dish pistons do so they would be all right too.
#49
AFR's!!!!
Another vote for AFRs could and were used right out of the box, sort of...8 years ago now and ZERO issues.
Just for insurance I had my expert builder who did the lower end machine work and build, despite him telling me he had never had an issue with AFR's, check my AFR heads AND guess what? They were perfect right out of the box back in 2013/14...........still today....
#50
Get a <$50 bore scope camera from Amazon or Ebay and take a look at the pistons then you'll know.
Sticking with 64cc would be my suggestion so you can re-use them later when you build another engine or bore and re-piston the one you have.
interpon (01-25-2021)
#51
Probably been decked , my black L82 must a had a touch up on the deck at one time as the numbers are real hard to read , I can make out about half of them once we got the heads off , paint and sand off and they stick out a little better
#53
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I just pulled my valve covers off my car to see which heads it has. The Chevy 350 thats in it makes almost no HP and its embarrassing. I realized now that the heads I have, GM 462624, are terrible heads and have a 76cc chamber. I dont know what cam I am running or anything else other than the car has a '78 Chevy 350 and the Muncie 4 speed. If I change the heads will I get more power or am I wasting money without doign a complete rebuild?
