Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly??
I know that Ecklers sells such assembly but not with the offset trailing arm.. Where can I get a offset trailing arm + bearing + spindle assembly??? It has to be the offset trailing arm!
:cheers:
Olivier
:cheers:
Olivier
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (GrandSportC3)
I got mine from Bairs - complete with all stainless parking brake hdwr. new rotors etc...
I cant say enough good things about Bairs, their people are knowledgable, friendly and courteous - cant do much better - their prices are excellent as well.
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I bought mine from Art Dorsett at VANSTEELS in FL. Art builds the Offset T-Arms for Ecklers and many other suppliers along with probably the best spindle/beariing setup service.
Art also has HD/Custom Halfshafts and any other need you might have. JIM :seeya
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (PROSOUTH)
:cheers:
Olivier
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (fauxrs)
:cheers:
Olivier
Just spoke with Dan at VanSteel... It looks like I'm going to get my offset trailing arms/bearing assembly there...
:cheers:
Olivier
:cheers:
Olivier
My bearings are there getting rebuilt and assembled on new offset arms right now :)
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (phoenix)
:cheers:
Olivier
Olivier,
What is the price you were quoted? What is VanSteel's phone #?
Thanks!
Thanks!
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (Gordonm)
Looks like somebody is going to get wider tires for more traction. :thumbs:
For now - I'm going to stay with my current setup, but in a couple of months I will get some 10 - 10.5 inch wide rims and above mentioned tires!
:cheers:
Olivier
Re: Who sells a OFFSET TRAILING ARM + BEARING + SPINDLE assembly?? (WA 2 FST)
Olivier,
Thanks!
Thanks!
800-418-5397
Fax: 727-561-7399
:cheers:
Olivier
How much are those? They are 2" offset? - Right?
:cheers:
Olivier
:cheers:
Olivier
:cheers:
Olivier
Yes 2" offset $1190 complete not including the core refunds on my existing bearings and trailing arms. All told $820 after core refund.
:cheers:
Olivier
:cheers:
Olivier
That's cheap!! It will cost me more at VanSteel.. However - the good thing about VanSteel is that I will have my trailing arm/bearing assembly tomorrow already
Theyve been on the car for over a year with no problems - the rear end still looks as good as the day I built it - but I must confess - I wash it when I washt the car. :crazy:
Until I looked at the reciept I had forgotten how good a deal I got from Bairs, part of the reason was that I had (relativly) new SS parking brake hardware on the existing bearing assemblies, because of that I got a pretty deep discount on the bearing assemblies - the trailing arms were $300 for the pair and the bearing assy's were about $260 each.
:cheers:
Olivier
