73 turn signal stalk button - what was it possibly for?
Good evening all,
I am in the process of dying the column on my 73. I am replacing the lever for the turn signal and when I tried to remove the original I found it had a wire connected to it. It has a button on the end that is far as I can tell is not a two position button you just push the button and it must close a switch inside of it. I am pretty certain it is not original but what could this have been used for? Was it a common modification in these cars? See the attached pictures for the connector that comes out of the column for it.
Scott
Scott
ScottEwine (07-13-2020)
Cruise control wasn't available in C3's until 1977 or 1978. A prior owner installed cruise (or was thinking about it and actually got the lever/switch installed. Even if the car does not have the other cruise equipment, put that lever/switch back in when you reassemble. You can add cruise later and use that switch to engage it.
(Note: that is an early switch that does NOT have on/off or RESUME buttons also. You can use it to engage a cruise system that is always turned ON. A full-feature turn/cruise lever would be better.)
ScottEwine (07-14-2020)
