Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-26-2002, 04:52 PM   #1
OHSIXX
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14
Support Corvetteforum!
OHSIXX's Avatar
Default Hurst Competition Plus Shifter Inastalled Today
Got it in today! Gears are much closer together. Everything is pretty stiff. Difficult to get into reserve and first gear, but doable.
Assuming this is normal and everything will eventually loosen up. If you have the Hurst Shifter please post your experience.
OHSIXX is offline   Reply With Quote
Old 11-26-2002, 05:17 PM   #2
Alwyn678
CF Senior Member
Alwyn678's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (OHSIXX)
A buddie and I put one in his 74 and it was pretty tight........but not difficult to get into any gear or reverse.........
Alwyn678 is offline   Reply With Quote
Old 11-26-2002, 05:27 PM   #3
45ACP
CF Senior Member
I hated mine. After two days of use of my brand-new shifter, I decided to remove it and go back to the stock shifter. I was delayed in getting it out and so lived with it for two weeks. It was an unhappy two weeks.
1. The shift lever was too long for my taste, 2-3 inches longer than stock.
2. The throws were no shorter than the stock shifter in the "short throw" mode.
3. The lack of a lock-out for reverse was very annoying. It was impossible to do a hard, fast shift from 4-1 or 3-1 without overshooting into reverse. Only very deliberate downshifts were possible.
4. Because of the direct mounting to the tranny (as opposed to the crossmember), it transmitted more noise and vibration, though this is a very minor complaint.
5. It felt no more "precise" to me than the stock unit.
I believe there may be something to be said for the ruggedness of the unit and the use of the shift stops in drag-race only applications, but I found it to be a waste of time and $'s for what I wanted.
I should probably mention that I have a perfect or near-perfect stock shifter in my car. It is not that way by accident - when I bought the car years ago it was one of the first things I tore apart and tweaked. An untouched and worn stock arrangement would likely not have faired as well in a comparison.
I hope you are more satisfied with yours than I was with mine.
[Modified by 45ACP, 5:28 PM 11/26/2002]
45ACP is offline   Reply With Quote
Old 11-26-2002, 05:40 PM   #4
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
If "stiff" and "tight" translate to precise yep :yesnod: that's the way a Competion Plus feels. If it is difficult to find or gears hard to engage them, something is missajusted or worn elsewhere. If one can find no improvement over the stock shifter I would start over with the installation...and this time follow the instuctions :cheers:
yellow 72 is offline   Reply With Quote
Old 11-26-2002, 05:44 PM   #5
OHSIXX
CF Senior Member
OHSIXX's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (45ACP)
I did not use the shift lever that came with the Hurst, but a stock "look alike" that is the same length as the stock lever. So, there is not a noticable appearance change.
The throws are much shorter and very crisp; you can hear it snap into gear. I think it is just logical the shifts will loosen up over time. My biggest concern is getting it into reserve which I am able to do in a matter of seconds, but it does take a little effort and does not just snap into it.
It feels like a new part that needs "breaking-in."
Old 11-26-2002, 05:54 PM   #6
rafox77
CF Senior Member
rafox77's Avatar
If the shifter is installed properly with the neutral gates lined up right, you should have no problem finding reverse. Mine was perfect from day 1, and thankfully has not loosened up at all.
Just curious, who downshifts hard from 4th to 1st, and why would you want to?
rafox77 is offline   Reply With Quote
Old 11-26-2002, 07:30 PM   #7
OHSIXX
CF Senior Member
OHSIXX's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (rafox77)
Sorta feeling a little better about the shifter. It is such a dramatic difference maybe it just takes a little getting use to since my stock shifter was loose as a goose.
Did a little practice shifting and am now becoming more comfortable with it. Reverse does take an extra second or two, but I think the Hurst is going to be a big improvement over the stock. :)
[Modified by OHSIXX, 7:56 PM 11/26/2002]
Old 11-26-2002, 08:09 PM   #8
Gordonm
CF Senior Member
Gordonm's Avatar
Reverse just takes a little getting used to. this shifter is so much better tha nthe stock shifter. Never miss a gear with the Hurst. If yours is not shifting better than the stock unit something is wrong or misadjusted. The Hurst is way better than the stock. Shorter throws and smoother shifting. It will loosen up a little as you drive it more.
Gordonm is offline   Reply With Quote
Old 11-27-2002, 12:31 AM   #9
MikeC
CF Senior Member
MikeC's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (Gordonm)
My hurst is great, I'd never go back to stock. as for the 4-1 shift, I've never had a problem with putting it into reverse accidentally. The throws are a little longer than I'd like but that isn't hard to change.
AFter two years, mine is still tighter than ever.
MikeC is offline   Reply With Quote
Old 11-27-2002, 08:22 AM   #10
OHSIXX
CF Senior Member
OHSIXX's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (MikeC)
One of my e-mail buddies who has the Hurst on two vettes told me the reverse is meant to be that way to prevent mistakes. Also, it takes it longer to loosen up because it is used less frequently.
Makes sense to me!
Old 11-27-2002, 08:47 AM   #11
chuck d
CF Senior Member
chuck d's Avatar
Hi OHSIXX:
I have a Hurst Competion Plus with a Look-Stock lever and found it a marked improvement over the stock shifter setup. Reverse is stiff on purpose, to keep you from selecting reverse by mistake. Also Hurst makes many different levers for thse shifters (short,long curved etc.). I think you did the right thing if you are ever going to drive your car hard.
Chuck D
chuck d is offline   Reply With Quote
Old 11-27-2002, 11:08 AM   #12
fauxrs
CF Senior Member
fauxrs's Avatar
As noted by others - difficulty getting into reverse is intentional. while there is no lockout, unless something is wrong with the shifter I can see no possible way to accidentally shift into reverse. It takes a concerted effort to get through the reverse gate on my shifter.
Everything else is very precise with nice "snick - snick" sounds during shifts. Definitly a more robust unit. I still have the shifter arm that came with the shifter and it is a tad long - I may go over to the look alike shifter arm if it is that much shorter.
fauxrs is offline   Reply With Quote
Old 11-27-2002, 01:26 PM   #13
79 Midnight Blue L82
CF Senior Member
79 Midnight Blue L82's Avatar
45ACP
Do you still have your Hurst shifter that you really did not like? If so, would you like to sell it? I might be interested as I really despise my worn out OEM shifter.
79 Midnight Blue L82 is offline   Reply With Quote
Old 11-27-2002, 02:00 PM   #14
L82-JWS
CF Senior Member
L82-JWS's Avatar
Send a message via AIM to L82-JWS
Default Re: Hurst Competition Plus Shifter Inastalled Today (79 Midnight Blue L82)
I recently installed the Hurst Comp Plus also in my 79. What a difference. The
stock shifter was much more loose, where as the hurst is tight and crisp. Reverse is a tad difficult, but as stated earlier, its by design. enjoy! :)
L82-JWS is offline   Reply With Quote
Old 11-27-2002, 03:21 PM   #15
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (L82-JWS)
I was very happy with that shifter on my old 4spd :yesnod: . Enjoy :cheers: !
SmokedTires is offline   Reply With Quote
Old 11-27-2002, 03:28 PM   #16
OHSIXX
CF Senior Member
OHSIXX's Avatar
Default Re: Hurst Competition Plus Shifter Inastalled Today (SmokedTires)
After a full day of driving and shifting gears, I am wondering why I waited so long to get this thing on.
It is at least a thousand percent improvement. :)
Old 11-28-2002, 11:31 AM   #17
Bob in Dallas
CF Member
The reason it is "difficult" to get into reverse is the spring which must be overcome to reach reverse. This helps prevent accidental moves to reverse when downshifting. Proper allignment of the neutral gate (read the instructions on installing a pin and adjusting shift lever length) make the shifting quick and precise. After missing a shift on a new Z-28 in '68, and watching the tach hit 8000, the next stop was to buy a C-Plus shifter. Problem cured.
Bob in Dallas is offline   Reply With Quote
Reload this Page Hurst Competition Plus Shifter Inastalled Today
Tags
1972, 72, competation, competition, compititon, corvette, feels, hurst, loose, manual, problems, reverse, shifter, shifting, spring, wrong
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
