What fuel pump pressure needed?
Old 11-27-2002, 11:50 PM
SpyderD
SpyderD's Avatar
Default What fuel pump pressure needed?
What psi should the fuel pump be for a holley 750 double pumper? Mechanic says my holley 7 psi fuel pump is to high and it should be about 4 psi. I just want to get another opinion.
Old 11-27-2002, 11:54 PM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
Default Re: What fuel pump pressure needed? (SpyderD)
Is the engine stock??? :smash: What kind of driving?? :smash:
Old 11-28-2002, 07:56 AM
ED DINAPOLI
ED DINAPOLI's Avatar
7 pounds should be ok. The needle and seat in a Holley with support up to 9 pounds. If you have a high performance engine you will starve it with 4 pounds.
Ed
Old 11-28-2002, 11:52 AM
SpyderD
SpyderD's Avatar
Default Re: What fuel pump pressure needed? (SanDiegoPaul)
The engine bottom end is otherwise stock '81 350, soon to be rebuilt but probably with stock parts. Top end and cam is all high performance (Edelbrock RPM intake).
My driving is just in town type, occasional spirited runs on open roads.
Would a regulator be a good idea?
To What fuel pump pressure needed?
Quick Reply: What fuel pump pressure needed?
