Oil pan gasket and sealant
Hello!
Need to buy a new oil pan gasket for my 489ci BigBlock. Please can you recommend me a high quality one piece oil pan gasket that seals for 100%? And which sealant to use on the corners? Want to buy at summit or jegs.
Thanks, Günther
Thanks, Günther
65-90 Big block
felpro OS30061T (one-piece blue silicone rubber PermaDryPlus gasket with SnapUps)
https://www.summitracing.com/parts/fel-os30061t
https://drivcat.com/overlays/part-de...Set&brandId=FL
https://drivcat.com/livedocs/Oil%20Pan%20Sets.pdf
https://drivcat.com/livedocs/2008(2-2).pdf
https://drivcat.com/livedocs/PermaDryPlus.pdf
dab of rtv in corners
I went with this one piece gasket. Sealant free but does say to add a little to the corners. So far working great. Make sure you get the one with the four ‘clips’ to help hold it up during installation unless you have the engine out.
Big2Bird (05-23-2020)
