Poly vs rubber
FWIW, I put poly in for CA bushings, trans mount, trailing arm bushings, sway bar mounts. No squeak, rides wonderful on our lousy Alaskan roads, handles like a slot car but thats likely due to other stuff i did as well. I have no complaints. However, prior to Poly even with semi worn rubber bushings the car handled ok. It's when the trailing arm bushings went is when the car was a mess to drive. Rubber works fine. Poly work fine. Just use a quality product like others have said. Just freshening up the suspension is going to make you happy, you will not regret doing either if you use good products IMHO.
I am thinking about using Energy Suspension poly bushings on the 2 rear trailing arm pivot mounts. I understand these can be installed without removing the trailing arms completely as they are not pressed in and staked with a tool. Is this true and are the poly bushings the same width as the stock ones or are more (or less) shims just used?
Johnny joints are the answer here.
CanadaGrant (04-14-2020)
Just another Corvette guy
Just an FYI, this thread came up on the C2 board last week:
https://www.corvetteforum.com/forums...e-bushing.html
Thanks guys. I had heard some sellers were pawning off inferior "poly" bushings that were known to fail but figured Energy Suspension would know what they have or would have quit producing it but who knows... Some guys swear by the stuff but maybe rear control arms isn't the place for it.
interpon (04-14-2020)
I had Bairs put rubber trailing arm bushings in when they rebuilt my arms. They are the only rubber bushings left in my car. I've been happy with Energy Suspension poly bushings everywhere else (and heim-jointed strut rods, steel engine mounts, etc).
