69 427 ac crank pulley. Help
Have a 427-400 hp ac car. Need crank pulley. Is it a 2 or 3 groove and reading has me thinking it’s cast iron. Anyone have pics or a part number and know where I can find one?
Old Pro Solo Guy
I did that research for mine. Paragon Corvette says 69s used both steel and cast 2-belt crank pulleys depending on the engine and the VIN #. The water pump pulley is a 3 belt on all BBs. I presently have all three if you need pics or numbers.
Old Pro Solo Guy
I'd be willing to let the 72 OEM steel crank pulley go if anyone wants it.
Old Pro Solo Guy
As far as I know BB C3s never had a 3 groove crank pulley. Only the steel or cast 2 groove ones above.
The water pump ones did vary by year, some 2 groove and some 3 groove.
Old Pro Solo Guy
From 1983 Chevy Parts Book. Only 1923 or 108 mentioned for 67-72 BB cars. But does not seem to cover all BBs. For example the 74 454 w/ AC uses a diff part # pully. The 69 427 H/P listing says exc 3x2. Nothing listed for 3x2? Is it possible a number got dropped? Does anyone have an older parts book?
