Radiator fan too close to cross member
now figure out how to check your drive shaft alignment. front may want to be back where it was. rear may be too high. may also be spot on, but you want the u-joints straight more than you want that fan to clear the crossmember.
Don't know if this helps much, but here is a pic looking down the shaft and another with a broom handle lying next to the drive shaft as a straight edge.
Seems pretty decent to me, what are your thoughts?
