Changing the Differential Fluid
A little Sunday project. First time changing the diff fluid on the '81. Don't have the bottom drain plug,, why not?? Another genious design!
My hose from the fluid pump isn't really flexible and doesn't appear to bend down; only to the front of the diff.
Is the trick to raise the rear so that the fluid pools as far forward in the diff?
A little Sunday project. First time changing the diff fluid on the '81. Don't have the bottom drain plug,, why not?? Another genius design!
Just curious? How often are the clutch packs supposed to be serviced? Doesn't that require dropping the carrier and diff? And then basically rebuilding the diff?
Put a wire coat hanger or some support on the suction hose, thats what i used and left the soft part extend a couple inches to poke around and pump out what you can..worked pretty good
eddp (11-03-2019)
Thanks for the advice. It took over 60 oz. including 4 oz of LSA.
If you have any room, i put 2 , 4 ounce bottles of the gm additive per this forum.
Received 2,143 Likes
eddp,
Why no drain plug? Lets just say for sake of argument that it wouldn't cost GM a penny to add one. However, 40 yrs later, someone would be asking:
Why does my rear axle drainplug drip?
Why does my trans - pan plug weep?
Just like an oil pan plug, it will drip. Trust me.
eddp,
I've watched several You Tube vids on corvette diff fluid and several have had a plug at the bottom and a fill on the side of the case.
