Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2002, 04:13 PM   #1
Ki m Le
CF Senior Member
Ki m Le's Avatar
Default Muncie M20 vs M21?
What are the adv/disadvantages between the two Muncie trans?
Ki m Le is offline   Reply With Quote
Old 11-05-2002, 04:56 PM   #2
burners
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
burners's Avatar
Default Re: Muncie M20 vs M21? (Ki m Le)
One has close ratios the other has wide ratios.
M-20 M-21
1st 2.52 2.20
2nd 1.88 1.64
3rd 1.46 1.28
4th direct direct
I love my M-21. The gear spacing is tight, the revs are always up. Lots 'o fun. Gear selection all depends on the power curve the engine puts out.
[Modified by burners, 2:57 PM 11/5/2002]
burners is offline   Reply With Quote
Old 11-05-2002, 05:04 PM   #3
Fevre
CF Senior Member
Fevre's Avatar
Default Re: Muncie M20 vs M21? (burners)
Waht burners said. The M-20 is more of drag race tranny while the M-21 is more of a road racing tranny.
Fevre is offline   Reply With Quote
Old 11-05-2002, 06:04 PM   #4
Wrencher
CF Senior Member
Wrencher's Avatar
Default Re: Muncie M20 vs M21? (Fevre)
Unless you have a BB :D Then it just doesn't matter.... M-20 in mine.
Hans
Wrencher is offline   Reply With Quote
Old 11-05-2002, 06:51 PM   #5
Schmucker
CF Senior Member
My dad always liked having the M20 in his '64 because it gave him a lower first gear to just get the car barely rolling.
Schmucker is offline   Reply With Quote
Old 11-05-2002, 06:58 PM   #6
74vetteman
CF Senior Member
They were installed in cars with different differential gear ratios. 3:70 and numerically higher were given the M-21, 3:55 and lower were given the M-20. The lower first gear in the M-20 got the highway geared cars off the line better.
74vetteman is offline   Reply With Quote
Old 11-05-2002, 07:01 PM   #7
74vetteman
CF Senior Member
Default Re: Muncie M20 vs M21? (74vetteman)
Also, the higher gear reduction of the M-20 will probably make it slightly weaker due to more torque multiplication. However, mine is living behind almost 500 ft/lbs, and plenty of drag racing. Good thing I am running street radials though!!
Old 11-05-2002, 08:00 PM   #8
73 LS-4
CF Senior Member
73 LS-4's Avatar
not nescessarily true, there was a standard gear ratio with an M-20 or 21 but there were also optional gear ratios and this depended on year, my 73 was originally a 3.36 with an M-21, now it's a 3.55 and a much better combination in my oppinion with the M-21.
:cheers:
Pat Kunz
73 LS-4 is offline   Reply With Quote
Old 11-05-2002, 11:17 PM   #9
74vetteman
CF Senior Member
Default Re: Muncie M20 vs M21? (73 LS-4)
[QUOTE]They were installed in cars with different differential gear ratios. 3:70 and numerically higher were given the M-21, 3:55 and lower were given the M-20. The lower first gear in the M-20 got the highway geared cars off the line better.
My bad! Well, take what I said as a rule of thumb, not necessarily in every case. :cheers:
Old 11-06-2002, 12:32 AM   #10
Schmucker
CF Senior Member
I dunno, my dad didn't have any trouble with his M20. 5.87's in the rear, 550hp out of a 302, 10k launches. He ground off every other synchro tooth so it slipped into gear better. That's about it.
Old 11-06-2002, 08:19 AM   #11
Ki m Le
CF Senior Member
Ki m Le's Avatar
Default Re: Muncie M20 vs M21? (Schmucker)
Thank you all for replied. I have the 427, L36 motor, M20 and M21 ) Muncie just over hauled them myself with all the part for conversion to manual from Auto. The car is 69 vert # matching with 350, 300HP, TH400 and 3:36 rear. All of # matching stuffs will be stored away for originality. With your inputs, I have to make a decision which Muncie to put in the car. BTW, It's going to be street driven car and occasionally, racing against the guy at work with a 64 GTO with 389, M20.and 3:55 rear. I don't want to be defeated again!
[Modified by Ki m Le, 7:20 AM 11/6/2002]
Old 11-06-2002, 10:27 AM   #12
Flareside
CF Senior Member
Flareside's Avatar
My L36 '68 is currently running a stock trans and rear, an M21 and 3.55. I don't like this combo one bit, and the day I rebuild the transmission is the day it becomes an M20! I plan to run a 3.36 axle with the M20. This combo would give both a better launch and lower highway revs than my current combo. The L36 makes plenty of torque, so the M21/3.55 is a major mismatch. I honestly can't think of one senario where I would want to run my current combo on the street. Torquey big block, high strung small block, no way.
The M21's 2.20 first gear is way to low for a good launch. Just look at all the aftermarket transmissions today, their first gears are usually 3.00+.
Have you guys seen the new M22 gears that are available with the M20 gear ratios? M22s usually have the M21 ratios. I want one!
Flareside is offline   Reply With Quote
Old 11-06-2002, 07:49 PM   #13
OatBoy
CF Senior Member
Default Re: Muncie M20 vs M21? (Flareside)
why is it sometimes called the "rock crusher" thats what i wanna know :cheers:
OatBoy is offline   Reply With Quote
Old 11-06-2002, 11:48 PM   #14
Schmucker
CF Senior Member
Default Re: Muncie M20 vs M21? (OatBoy)
I figure it is because if you put rocks in it, it would be strong enough to crush them. It is a heavy duty trans. I doubt it would crush the rocks.
Old 11-07-2002, 12:58 AM   #15
Robert Holtman
CF Senior Member
Robert Holtman's Avatar
Switching from a M21 to a M20 wont change you highway cruse RPM's at all. Fourth gear is 1 to 1 in m20, M21 and M22. You can only lower your highway RPM by increasing your tire diameter, lowering your rear gear ratio or putting in a overdrive unit or transmission.
Robert Holtman is offline   Reply With Quote
Old 11-07-2002, 07:44 AM   #16
'79ProwlerOrange
CF Senior Member
'79ProwlerOrange's Avatar
Send a message via AIM to '79ProwlerOrange
sounds torquey!
'79ProwlerOrange is offline   Reply With Quote
Old 11-07-2002, 09:28 AM   #17
Flareside
CF Senior Member
Flareside's Avatar
If you had driven in an M22 car, you would know why they call it the rock crusher. Some think it sounds like it is crushing rocks inside :)
Old 11-07-2002, 12:00 PM   #18
DJ Dep
CF Senior Member
St. Jude Donor '05-'07
DJ Dep's Avatar
Only the M22 trans is called "The rock crusher". From what I understood, it was because of the sound the gears made while driving. They aren't exactly known for "silent running" ;)
Dep
DJ Dep is offline   Reply With Quote
Old 11-07-2002, 12:51 PM   #19
MikeC
CF Senior Member
MikeC's Avatar
Default Re: Muncie M20 vs M21? (Dep)
M22 is a rock crusher because of the gear noise. to reduce gear noise in a normal car, engineers put in a helical cut gear at 44 deg( I believe). THis provides a quite comfortable ride but at the cost of strength and the additional side loading on the tranny case caused by the gear tryto get pushed into the case. THe M22 has 22deg helical cut gears, increasing strength and reducing loading on the case but they are as noisy as all hell.
MikeC is offline   Reply With Quote
Old 11-07-2002, 01:01 PM   #20
ericshaw
CF Senior Member
ericshaw's Avatar
My 76 has an M22 w/a 3.73 rear... gets me in trouble with the law quite a bit around town :D
ericshaw is offline   Reply With Quote
Reload this Page Muncie M20 vs M21?
Tags
20, corvette, crusher, gear, high, m20, m21, m22, muncie, people, ratio, rear, rebuild, rock, rpm, runs, service, trans
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
M20 or M21? JR's66coupe C1 & C2 Corvettes 12 01-24-2004 01:46 PM
"ROCK CRUSHER" TRANY? OkeeGuy C3 Tech/Performance 12 05-13-2002 01:58 AM
1979 L 82 4 speed tranmission catfishjack C3 Tech/Performance 9 01-21-2002 10:07 PM
M21 vs M20 Elmer C1 & C2 Corvettes 15 09-11-2001 09:03 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
