Adding duel exhaust to a C3
Old 04-14-2019, 05:08 PM
66ca
66ca's Avatar
Default Adding dual exhaust to a C3
I went one day last week and had duall exhaust put on my stock 81. They took out the catalytic converter and ran 2 new pipes to the rear, with new magnaflow mufflers.
My question is how does this affect the rest of the engine and smog system, because wasn’t that line on the converter somehow tied to the smog pump?
Old 04-15-2019, 07:15 AM
derekderek
derekderek's Avatar
Received 3,387 Likes on 2,632 Posts
I assume you are in a state that doesn't emissions test your year? Cuz the way you say smog implies California. I can't see a shop removing your cat in a state that does smog testing on that year. In fact, I cant see a shop pulling the cat even without emissions. The stuff is still required to be installed. But to your question, at this point I would store the AIR pump with the cat...
Old 04-15-2019, 08:16 AM
66ca
66ca's Avatar
That’s correct, I live in Texas. And a part of Texas that doesn’t require any emission tests.
But my question was , is the system on the car basically doing nothing since the cat has been removed
Old 04-15-2019, 08:33 AM
sstonebreaker
sstonebreaker's Avatar
The AIR pump is mainly used to light off the cats when they're cold.
Old 04-15-2019, 09:07 AM
66ca
66ca's Avatar
So without the cat being there, the whole system is basically doing nothing now right?
Old 04-15-2019, 09:17 AM
sstonebreaker
Pretty much. It's not hurting anything, but it's not doing anything, either.
Old 04-15-2019, 09:44 AM
66ca
66ca's Avatar
Ok. That’s what I was wondering
thank you
Old 04-15-2019, 10:54 AM
Gunfighter13
Gunfighter13's Avatar
Old 04-15-2019, 07:34 PM
How Are You
How Are You's Avatar
Old 04-15-2019, 08:18 PM
66ca
66ca's Avatar
How are you.....
i realized what I did after posting this and it wouldn’t let me edit it. Lol
Old 04-16-2019, 10:31 PM
DaveL82
DaveL82's Avatar
You can remove the pump but keep it and all parts if needed later. Your pump outlet went right into the cat if I recall correctly where my 80 had the pump inject into the manifolds. I removed my pump also.
Is your car still running the computer controlled carb and distributor? Don't think this will matter though.
To Adding duel exhaust to a C3
Quick Reply: Adding duel exhaust to a C3
