LS Swap - Will bolt-on shifter shaft work with Tremec shifter?
Good Morning All,
Does anybody know if the bolt pattern on this shifter shaft:
https://www.zip-corvette.com/68-76-4...ter-shaft.html
will match this Tremec shifter?:
Thanks,
Scott
Thanks,
Scott
Not exactly sure on the Tremec, but I used that shifter on a Richmond 6 speed (same bolt pattern). That shifter sat up a bit high because of the tranny and shifter mount location. You might end up wanting it cut/welded anyway.
ScottEwine (02-21-2019)
I have a 66 with a Tremec and I used that shifter and it bolted right in. The handle also fit the Hurst Competition Plus shifter I had in the car when I had a Muncie transmission. Jerry
C3 of Year Finalist (track prepared) 2019
If that is the same shifter handle as Hurst sell, then I used it on my tremec tko600 box with modified stock Tremec shifter (modified with a welded in offset to locate it correctly in the factory console). I also used a shifter plate from Hurst to show the correct shift pattern but keep it all looking factory.
As from supplier, with shifter modified to move it sideways.:
The rotation required to locate it better in the console. Unfortunately I don't seem to have taken a picture after welding.
Resultant position:
Once car was reassembled (in 1st gear in picture):
Resultant position:
ScottEwine (02-22-2019)
Resultant position:
Resultant position:
Scott
