Twin Turbo C3 build
Twin Turbo C3 build
For anyone thats interested - Iam doing a twin turbo C3 build - pics below
Tech details -
engine - LSX B-15 crate engine from GM
Gearbox - Tremec T56 magnum
CTS- V - accessory drive kit from GM
Engine mounts - ICT engine swap plate and energy suspension motor mounts(without preload plate - dropped the engine a extra 10mm by not using plate - energy suspension said it was ok to run like that) This thread covers it all in detail - https://www.corvetteforum.com/forums...ne-mounts.html
Steering - Steeroids rack system - there is a ton of room between the oil sump and rack, engine is mounted as low as possible(if i tried to go any lower the oil pan would be scraping off the road) - the key here is the choosing a slim oil pan, i used the holley oil pan- it still has a good capacity, but is really slim at front, comes with drain holes for turbos
link- https://www.holley.com/products/acce...ns/parts/302-3
Headers - stainless steel works headers 1 - 7/8 tubes - 3 inch outlet - not cheap - but vastly thicker metal compared to cheap versions
Turbo's - borg warner s362 fmw twins
Radaitor - will use my dewitts rad, will need to layed forwards and flater
Intercooler - will us my old procharger one for now
Holley EFI system - dominator ecu - holley loom etc
Tech details -
The following 2 users liked this post by corvettedave383:
amandico82 (02-04-2021),
Metalhead140 (11-08-2018)
Dementer sole survivor
Received 6,339 Likes
2016 C3 of Year Finalist
I was watchiing Engine Masters and looking at all the turbo combinations and was just wondering how it would fit. Particularly the accessory drives, intercooler radiator and exhaust routing. Now I will know. Good luck and I'll be following along. Thanks in advance for the info
Received 1,891 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Looking good! Keep feeding us the details!
JIM
JIM
Impressive! Keep us posted for sure
A C (05-08-2019)
Looks great!! Looking forward to progress.
It's a tight squeeze as you've already figured out. On my single front turbo, I had to optimize the space up front.
What are the two holes for in the front?
Where are you going to route the exhaust?
new progress - turbo downpipes/exhausts tacked together - 3 inch pipe - you cant get the downpipes to be 100% symmetrical in the engine bay, because the way the engine sits towards the passenger side, ive mounted the turbos slightly higher, to allow me to use 45 degree bends, for best exhaust flow, wanted to avoid 90 degree bends etc, they will stick out of bonnet, some advantages to that better engine bay cooling, nice fresh cool air coming into turbos and better exhaust flow, which equals to more power lol
amandico82 (02-28-2021)
holes in front for more engine bay cooling, when i had procharger fitted
see new pics for exhaust routing
Some new progress - wastegates fitted(tial 45 mm) and radiator(dewitts) fitted in lower and vertical position, still 6 inch clearance bewtween bottom of rad and road
corvettedave383 (12-12-2018)
Very Nice.
