New starter
New starter
Hi, I'm looking to replace old and heavy starter with a mini and new starter.
Any suggestions? Also, looking at some catalogs, it seems there are different number of tooth's, how can I check what I've got?
thanks
thanks
Powermaster Starters.
See their website and call their customer service techs with any questions.
Did you read the reviews?
It received a couple of poor reviews regarding gear engagements which would eliminate this starter as a choice for me.
You can get the correct Powermaster starter for your set up through Summit for close to the same price.
Yuo are right! thanks I'll go with the Powermaster one
I tried to get a Powermaster to work but never could get good engagement. Tried all kinds of shims.
I found this after reading the chevelle forum and I bolted it on with no shims and it worked on the 1st try. It's been fail free for years now.
https://www.dbelectrical.com/product...sdr0031-l.html
For a 168 tooth flywheel, I like the late model GM starters.
The GM part # is 8000598 and the bolts are 12338064. Autozone part DLG9990S. 1995 Chevy truck (3/4 ton) with 7.4L. Love the Autozone Duralast Gold parts warranty. Had to get a new starter after 10 years. Cost me $0.00.
Just make sure you get the special bolts since they have standard threads and metric shanks.
I've been very happy with my PowerMaster. Even their less expensive one at $130 has no problem cranking my 10:1 454.
As for the GM starter, that what I had before and I can't recommend them anymore. There are 2 versions available at the parts stores, either rebuilt or new Chinese copy. Both use very weak plastic gears and I had several of them blow up after a year or two. Sure Autozone gave me another one for free, but wondering when it's going to blow up again gets old.
I will take a quality more expensive part all day over the cheap lifetime warranty junk parts....just me.
My time and labor is worth more than the lifetime warranty scam.
Reminds me of the lifetime warranty on FWD GM wheel bearing hubs for cheap at Autozone OR no warranty Timken/SKF wheel bearings that are 2-3 times as expensive BUT I change them once and that is it.......who wants to change FWD wheel bearing hubs often? not me!
Dr. Detroit
Received 3,893 Likes
The CVR is the only one I will use now........I have bolted one of these to three of my Vettes....big and small block and also my 82' C20 454 before I sold it.......none of these required shims and they spin the engines over like they have no plugs in them...........all you have to do is clock it correctly....which is easy.
https://www.summitracing.com/parts/cvs-5323
Jebby
Jebby
I "second" the DB Electrical starters. They're $48. You can buy 3 or 4 of them for the price of a PowerMaster.
And they weight 7.5 lbs!!
I'm buying 2 of them and I'll just keep one stored away in the garage for when the plastic bits inside die. When they're this much cheaper than everything else and they fit well, I find it difficult to pay more for something else.
Adam
Adam
OldCarBum (11-01-2018)
My Powermaster 9004-12 has been shipped and should arrive next week.
