L46 Crankshaft w/no casting number
Old 09-12-2018, 04:30 PM
35035069c3
Cruising
35035069c3's Avatar
Default L46 Crankshaft w/no casting number
Hello Members and Experts,
I'm having my numbers matching 1969 L46 engine rebuilt. I know the crankshaft is forged due to the wide casting rib, however there is no casting number or stamp, just GM and (maybe an H - unrecognizable - sorry no pics at the moment) - Is this common, or do I have a problem? The block and engine type is correct for that period - 3932386. The car fits the early 69's in most of the facts I've read.
Thanks in advance
Old 09-12-2018, 04:34 PM
MelWff
MelWff's Avatar
Received 1,819 Likes on 1,608 Posts
It should have a number on one of the rough finished throws or counterweights towards the front of the crank. Do those areas look like someone has been in the engine before you and polished them?
Old 09-12-2018, 05:48 PM
35035069c3
Cruising
35035069c3's Avatar
The engine builder said he'd never seen one without numbers, he could also tell it had never been rebuilt.. it had the original compression head gaskets and the piston caps had the so called crack sound when removed. I know the previous (original) owner, and he said the only thing ever replaced was the camshaft, which happened to be done by my brother (Chevy Master Mechanic). It's very odd to me, so I thought I'd toss it out on the forum.
Old 09-12-2018, 09:36 PM
bashcraft
bashcraft's Avatar
Does it matter? Nobody will see it after its together.
Old 09-12-2018, 10:18 PM
EarlyC34me
Parts Sherpa
Support Corvetteforum!
EarlyC34me's Avatar
This is an example of what mine looks like/where it can be found
Old 09-12-2018, 11:03 PM
A88FXRS
A88FXRS's Avatar
aftermarket crank from china !!!!!!!!
Old 09-13-2018, 08:28 AM
stingr69
stingr69's Avatar
Received 1,044 Likes on 809 Posts
Chevy cranks have numbers. If yours actually does not show numbers, the numbers were either removed or it is not a chevy crank.
Old 09-13-2018, 10:55 AM
35035069c3
Cruising
35035069c3's Avatar
Once I get the long block back, I'll take a closer look. So far I've just been told it has casting identification "GM" and some unrecognizable character. Thanks everyone for your input - the aftermarket China crankshaft comment made me laugh.
Old 09-14-2018, 10:41 PM
Sky65
Sky65's Avatar
St. Jude Donor '05, '09, '15
Looks like 1182 to me. Same one I have in my 69 L46.Nice factory forged crank.
Tom
Old 09-14-2018, 10:43 PM
Sky65
Sky65's Avatar
https://www.corvetteforum.com/forums...ged-crank.html
Tom
Old 09-15-2018, 09:09 AM
stingr69
stingr69's Avatar
Tom
That picture is what it is supposed to look like. We just need to see the OP's crank.
Old 09-15-2018, 10:31 AM
Sky65
Sky65's Avatar
Woops! Sorry. Senior moment.
Tom
To L46 Crankshaft w/no casting number
Quick Reply: L46 Crankshaft w/no casting number
