TransGo TH350 Shift Improver Kit Installed...
Re: TransGo TH350 Shift Improver Kit Installed... (jerryp58)
I had read that auto transmissions, by design, can have two gears engaged at the same time, but I assumed they were both forward gears. That's an amazing concept: reverse and a forward engaged at the same time :eek: Can anyone corroborate that?
By the way, transbrakes work by applying pressure to the forward and reverse circuits at the same time to keep the transmission "locked", and then dumping the reverse pressure rapidly to take off.
[Modified by Apeiron, 6:05 PM 10/16/2002]
Re: TransGo TH350 Shift Improver Kit Installed... (Apeiron)
Guys, I'm going to have to take your word that TransGo is better than B&M. I've seen the animations of auto trans operation on shows like TNN's Popular Hot Rodding and I just took a look at a VERY interesting site http://www.howstuffworks.com/automatic-transmission.htm , but I'm afraid I'd have better luck simultaneously solving 4 Rubiks Cubes (one on each hand & foot) than I will understanding the hydraulic "circuits" that control band & clutch engaging & disengaging of gears in an automatic transmission, let alone the best way to modify that flow :crazy:
I don't particularly notice "hard shifts" at light throttle. Hopefully, my B&M'ized TH350 will hold out until I can put a 700R4 or 2004R in.
Paul, I'm glad you're happy with the upgrade :yesnod:
Thanks, Jerry. Yes I am pleased! But I do not understand the inner workings of automatic transmissions. As I noted earlier, there are many fine products in the marketplace. I have no basis on which to compare one to the other.
