Car sat, now smokes....
Old 03-24-2018, 09:09 PM
Blue79
Blue79's Avatar
Smokes only on start-up or all the time?
start-up = valve guide seals
continually = rings
Old 03-25-2018, 09:33 AM
JoeMinnesota
JoeMinnesota's Avatar
Hi FB#1... There are a lot of guesses here already, but really unlikely some major mechanical issue just happened while your car sat for 3 mos. and now suddenly became apparent. look for something small and simple. Are you sure it's oil smoke? Is it pretty blue?
Is this a carbureted motor? Are you running a choke - is the choke staying partially shut? Is it a Quadrajet? Not sure on the newer models, but on older models I had a friend whose secondary's would pull shut on partial acceleration after a tension spring failed - smoked constantly as it was really rich.
Have you pulled the plugs and looked at them - are they fouled with oil or just look like the engine is rich? It could even be ignition related, with you pumping unburnt fuel out the back due to missing cylinders.
It's got to be something pretty simple that just happened, unless you saw this problem before.
Old 03-26-2018, 08:11 AM
mikej454
mikej454's Avatar
Originally Posted by sassc3
maybe just the fuel stabilizer need to be run out...new fresh gas...
I agree. I have seen fuel stabilizers cause lost of smoke on startup. Also, fuel can suck up lots of moisture in a humid location. Just pump the old gas out and put in fresh. Carbs can also get REALY gummed up sitting.....
Old 03-26-2018, 08:40 AM
JoeMinnesota
Agreed. It can't be anything serious. It sat for 3 months, not 3 years.
Old 03-26-2018, 03:28 PM
FB#1
FB#1's Avatar
Its a 4 speed. Hoping to get to work on it this week. Non cooperative weather and no garage is killing me.....
Old 05-17-2018, 10:45 AM
FB#1
FB#1's Avatar
Blown head gasket.....fun....fun.....fun
at least I can put the sidepipes on it while I'm at it.
Wee (09-21-2018)
Old 09-21-2018, 09:55 AM
FB#1
FB#1's Avatar
Finally back together and running. Will post a video in the next few days.
Went ahead and put the aluminum radiator and fan in.
Sidepipes =
Old 09-21-2018, 10:38 PM
Wee
Wee's Avatar
Thank you for letting us know what the problem was...Glad it's fixed, have fun.
Brian
Quick Reply: Car sat, now smokes....
