Steering wheel stopped locking
Old 12-01-2017, 11:29 AM
kansas123
kansas123's Avatar
Default Steering wheel stopped locking
The tilt/tele steering wheel will not lock, where it was locking before. I have a picture that shows the lock rod; it moves up and down with pressure so the spring is okay; it just does not protrude enough to engage with the lock ring. Could something simple have happened when they removed the steering column and reinstalled it cause this? When I turn the ignition key to start, the rod goes farther down; it just does not return high/out enough after turning the key back to engage the lock ring anymore.
I am working on getting the horn operational also. Looks like everything is there to do that but not having much luck. So the rod that has to do with the horn springs alright, I need to see if the L shaped extension that is part of the horn contact is the right length. Should it be touching that spring loaded rod, or only touch it when the button is pushed? Thanks. I have copies and have been reading J Shay's papers, however I don't have the pics/diagrams.
By the way, the tilt/tele works with no problems.
Old 12-01-2017, 12:41 PM
MelWff
MelWff's Avatar
Received 1,819 Likes on 1,608 Posts
why would the column have been removed to install new carpets, was something else done to the car?
Old 12-01-2017, 01:24 PM
Greg
Just another Corvette guy
Support Corvetteforum!
Greg's Avatar
Received 3,836 Likes on 1,783 Posts
Old 12-01-2017, 02:19 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi k,
I'm sorry I can't help with your steering column woes.
But, I did notice the odometer numbers...that's a pretty NICE total if it's the first time around!!!!!
Good Luck with your column problem.
Regards,
Alan
kansas123 (12-01-2017)
Old 12-01-2017, 02:33 PM
kansas123
kansas123's Avatar
seems to me that the plate that the column has on it down there might be mounted ro the floorboard (and under the carpet). Been a while since I replaced the original with this tt one.
Old 12-01-2017, 04:15 PM
MelWff
MelWff's Avatar
have you actually asked the shop what they did that might account for your current problem? I changed carpets in my 69 and did not have to remove the steering column.
Old 12-01-2017, 04:33 PM
kansas123
kansas123's Avatar
loooong story, but don't care to ever darken their doorway again. 'Nuf said. Thanks though.
Old 12-02-2017, 04:28 AM
croaker
croaker's Avatar
It's probably the interlock cable coming from the Trans.
Old 12-02-2017, 04:57 AM
kansas123
kansas123's Avatar
BINGO, I BET THAT'S IT! Thanks a lot! Next warm day, will check it out!
Update: Looks like I can't get that lever to more closer to 1 o'clock so I have decided to pull the steering wheel back enough to move the spine 1 tooth clockwise; hope it's enough.
Old 12-02-2017, 07:34 PM
corvgreg
Emerging Vendor
corvgreg's Avatar
If the backdrive lever works and the ignition lock goes to the lock position there is another possibility.There is a spring that attaches to the lock lever and towards the bottom of the lock housing secured by a screw. The spring has a long u shaped extension that goes into the far right cavity of the plastic ignition gear. It puts pressure on the rod to fully extend it.
Old 12-03-2017, 05:58 PM
kansas123
kansas123's Avatar
Default Update, fixed the horn but no dice on Steering Wheel lock yet
Update: Could not get the steering column to let go and come out; figured that was telling me something so I gave up trying to get the steering wheel to lock properly.
Update: So the horn is fixed; the problem was with the horn contact, I believe this tt column came with a standard horn contact (?), I have heard they are different. the "_" part of the "L" on the contact was not long enough to reach the spring loaded rod; now it does and the horn works. However, I still haven't figured out where to mount it, there is no 'obvious' place, except somewhere in the front where the green wire reaches.
Thanks for everyone's input.
Old 12-03-2017, 08:28 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
David, don't know if you've seen or read any of Jim Shea's papers, but he's really the steering column Guru around here. Below are some of his papers you may find helpful.
If you have any questions for him, you can PM Jim directly here...
https://www.corvetteforum.com/forums...-jim-shea.html
If Jim can't answer your questions you have a serious problem...
Good luck... GUSTO
File Type: doc
File Type: doc
File Type: doc
File Type: doc
kansas123 (12-03-2017)
Old 12-03-2017, 09:15 PM
kansas123
kansas123's Avatar
Good luck... GUSTO
Thanks, yes. I have copies of his 3 papers but didn't have these diagrams, they will be helpful. This lock has really thrown me for a loop: the lever that is supposed to be at about the 1 o'clock position when the key is off is as far up as it can go, as it is making contact with the bottom of the power brake booster. I could swear it used to work but maybe it didn't. Maybe I am thinking of the standard column that I used to have. thanks again
Old 12-05-2017, 10:25 AM
Jim Shea
Jim Shea's Avatar
I don't ever recall the lower steering column lever hitting the power brake booster. I don't even remember anyone ever mentioning it.
Jim
Old 12-05-2017, 11:35 AM
kansas123
kansas123's Avatar
Jim
I double checked, the lever is not touching the booster as I had thought. I am starting to think the problem with the pin is with the sector, spring, maybe the pin itself. I have autopsied another column in the past and remember some of that workings, plus I have your diagrams, papers and service manual. Now I need the courage to get into that again. Thanks. This is the only think I can think of that I have yet to be check.
Old 12-05-2017, 01:11 PM
kansas123
kansas123's Avatar
Jim,
Will I have access to parts 24 thru 30 by removing part 15, or do I have to remove part 23 from the column itself? I am after the sector, pin and spring. Thanks
Old 12-05-2017, 09:21 PM
TimAT
TimAT's Avatar
Parts 23-30 will be accessible when you remove the upper shroud part 15. 24-25-26 is the spring that puts pressure on the tilt portion, ie., when you pull the tile lever the wheel snaps full up. #30 is a pivot pin that the lower part 23 tilts on. THe sector is #29, spring and lock pin are 27 and 18.
To Steering wheel stopped locking
Old 12-05-2017, 10:39 PM
kansas123
kansas123's Avatar
Thanks that is great news!
Old 12-06-2017, 11:17 AM
marc9889
marc9889's Avatar
You might mind the info on my blog useful. www.72Stingray.com > Steering column swap
Lots of photos. Hope it helps.
kansas123 (12-06-2017)
Old 12-12-2017, 09:30 PM
kansas123
kansas123's Avatar
Default Update on Steering Wheel (not) locking
So I dissected the tt steering column far enough to have access to the sector gear etc and it is not missing teeth nor is it 'off'; everything seems to be there and in very good shape. So I cleaned up the parts as best as I could and lightly oiled. My new question is, could I make a slight adjustment in the position of the ignition switch, thereby moving the switch rod, enough to get the lock rod to engage the lock plate? The reason I ask is because if I move the lock cylinder to the accessory position, the lock rod moves enough to lock the wheel. In the off position rod is just missing moving that much more to engage the plate so maybe just a little adjustment of the ignition switch and thereby, the rod... Thanks.
Quick Reply: Steering wheel stopped locking
