front vs rear wheel-to-brake clearance, which is closer?
Old 11-22-2017, 02:09 PM
71coupe
71coupe's Avatar
Default front vs rear wheel-to-brake clearance, which is closer?
I'm going to mock up a C3 hub assembly to check aftermarket wheel clearances.
Which has the tightest go/no-go clearances, front or rear?
Thanks in advance
Old 11-22-2017, 06:12 PM
MelWff
MelWff's Avatar
Received 1,819 Likes on 1,608 Posts
are you referring to the wheel mounting surface versus the sides of the brake caliper or some other measurement?
Old 11-23-2017, 04:13 AM
71coupe
71coupe's Avatar
I want to check some "no name" torque thrust style wheels to make sure the brakes clear. My car is in another state, so I cant use that.
Old 11-23-2017, 01:28 PM
MelWff
MelWff's Avatar
they need to be at least 15" in diameter but you need someone to measure the wheel mounting surface to caliper distance on a corvette and then compare that to the wheel to make sure the spokes of the wheel dont hit the caliper sides.
The manufacturer doesnt provide a application guide?
Old 11-23-2017, 02:55 PM
71coupe
71coupe's Avatar
No, these are vintage rims from the 60's. I found a person who has a stash of these wheels, some are magnesium...
Old 11-23-2017, 06:28 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Seems like they will need to be put on and checked. I have a few customers with the old school wheels and some use the spacers with extended wheel studs and others have special adapter hubs made.
DUB
To front vs rear wheel-to-brake clearance, which is closer?
Quick Reply: front vs rear wheel-to-brake clearance, which is closer?
