Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-07-2002, 10:26 PM   #1
MELVIN
CF Senior Member
Default 4 speed manual tranny owners READ: proper fluid level checks!
Im usually really picky on maintainance, but kept putting off changing out my 4 speed gear oil until today because there is no drain plug, just a fill plug: You must get under the car, suction pump the old out, and refill the reverse. I finally quit putting it off and got a hand operated pump today, and here is what I found
I only got about 1/2 a qt out. I thought maybe it was because I just couldnt get the suction hose in the right area inside the case from the filler plug, as you have to kind of move the hose around to get around the internal parts to get at all the fluid. But still, I only got about a 1/2 qt total
sucked out
So I went to pump in new stuff, and got a full 2 qts in before it started to dribble out (the proper fill)
point is, dont wait so long to check your manual tranny fluid. Its not hard to get to, its just you have to get your car up on jacks, remove the plug, get some sort of pump, and go from there. I couldnt beleive I let it go for so long, so low
By the way, what is the total fluid capacity for a 4 speed? Neither the factory repair manual or Haynes states the total capacity for a 4 speed. Just that you fill until it dribbles out the fill hole
At the same time I changed the rear end oil. Same drill, but this time got about 2-1/2qts out. Placed in 4 ounces of posi additive, and got in just about 2 1/2 qts of new rear end oil
MELVIN is offline   Reply With Quote
Old 10-07-2002, 10:46 PM   #2
Stingray1970
CF Senior Member
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (MELVIN)
I just looked in a 76 owners' manual and it says a four speed holds 3.0 pints
Stingray1970 is offline   Reply With Quote
Old 10-08-2002, 01:08 AM   #3
LAvetteman
CF Senior Member
St. Jude Contributor
sucked out
Hmmmm, I thought my rear only used 1.5 quarts, plus posi addit.
LAvetteman is offline   Reply With Quote
Old 10-08-2002, 08:32 AM   #4
MELVIN
CF Senior Member
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (71,454,4spd)
Sorry, my bad on the rear end. It only took 4ozs of additive and two, 23 oz bottles of GM rear end oil (just checked the trash)
But the tranny took a full 2-1/2 qts after pumping it as dry as I could before it started to dribble out
Old 10-08-2002, 09:12 AM   #5
Fevre
CF Senior Member
Fevre's Avatar
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (Stingray1970)
Click the image to open in full size.
I tried to put in 3 quarts, not reading the capacity very carefully, but only got about 1 1/2 quarts in before it came running out all over the garage floor. :(
Fevre is offline   Reply With Quote
Old 10-08-2002, 10:00 AM   #6
Tom454
CF Senior Member
Tom454's Avatar
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (Fevre)
Hey John...
Me & Mark just rebuilt his Muncie and we filled it before we re-installed it in the car....
The manual said 3 pints, and that is all we could get in before it started to come out the fill plug. We had it sitting on the kitchen table... we poured the oil in through the side cover (since it was still off), and when we levelled it correctly, the oil was right at the plug threads... just starting to dribble out. We left it at 3 pints, which seemed to be correct.
FYI
Tom
Tom454 is offline   Reply With Quote
Old 10-08-2002, 11:31 AM   #7
drspeedy
CF Senior Member
drspeedy's Avatar
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (Tom454)
Quote:
We had it sitting on the kitchen table... we poured the oil in through the side cover (since it was still off).
:lol: :lol: There must not be a Mrs. Mark!! :lol:
drspeedy is offline   Reply With Quote
Old 10-08-2002, 12:07 PM   #8
Marks69BB
CF Senior Member
Marks69BB's Avatar
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (drspeedy)
drspeedy Good call! But a lucky one; it was Tom's kitchen table! :lol: If you saw his garage at the moment you'd know why!
Constantly on the lookout for a new honey tho. (not ready for another Mrs. Mark just yet! :jester) Unlike the ex, she has to like vettes and put up with my infatuation with them.
Marks69BB is offline   Reply With Quote
Old 10-08-2002, 12:10 PM   #9
Fevre
CF Senior Member
Fevre's Avatar
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (Marks69BB)
Me too. She also has to put up with my inflatulation in them. :jester
Old 10-08-2002, 12:11 PM   #10
Cali,68,L-79
CF Senior Member
Cali,68,L-79's Avatar
What kind of tranny you have? I have both fill and drain I remove the drain plug and let it drain out Then with fresh 80/90 and a hand pump and 4' hose pump it throughout the tranny with the drain plug still off till all I get is nice clean oil. Then put on the drain and fill it up to the lower edge of the fill plug (just barely dribbling out)
Cali,68,L-79 is offline   Reply With Quote
Old 10-08-2002, 12:15 PM   #11
MELVIN
CF Senior Member
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (Cali,77,L-82)
4 SPEED, M22
Old 10-08-2002, 06:58 PM   #12
Cali,68,L-79
CF Senior Member
Quote:
4 SPEED, M22
Then what the hell do I have??? Saginaw?
Old 10-08-2002, 09:48 PM   #13
73 LS-4
CF Senior Member
73 LS-4's Avatar
My M-21 has drain and fill plugs, what year is your tranny? maybe the early muncies didn't have drain plugs.
:cheers:
Pat Kunz
73 LS-4 is offline   Reply With Quote
Old 10-08-2002, 10:16 PM   #14
Stingray1970
CF Senior Member
I think you have a sixth design ( 1974-1988 ) Super T-10.
Old 10-08-2002, 10:23 PM   #15
PRNDL
CF Senile Member
Support Corvetteforum!
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
From a corvettemagazine.com article by Alan Colvin:
" For the 1970 model year, there were two major changes to the Muncie four-speed. In previous years only the M22 transmission had a drain plug, however, beginning in 1970 all Muncie four-speeds now had a drain plug."
I do not have a drain plug on my 68 M20. John, You dont mean M22 "rock crusher" do you? You actually would have a drain plug if it was an M22, but more common M21 or M20 for 68 had the place for the drainplug, but none drilled. MJ
PRNDL is offline   Reply With Quote
Old 10-09-2002, 11:32 AM   #16
MELVIN
CF Senior Member
Default Re: 4 speed manual tranny owners READ: proper fluid level checks! (MNJack)
Fellas,
My "drain" and filler are the same hole. On the side, passenger side of tranny, about 1/2 way up the tranny body
My main point was this: Just make sure you have enough fluid. Mine was low as hell after putting it off for so long.
Old 10-10-2002, 06:06 PM   #17
Cali,68,L-79
CF Senior Member
Anything on the tranny case to verify?? Car is all original so want to know what kind of tranny I have.
Old 10-10-2002, 07:16 PM   #18
Larry B.
CF Senior Member
Larry B.'s Avatar
My original late 69 M-20 has a drain plug.
Larry B. is offline   Reply With Quote
Reload this Page 4 speed manual tranny owners READ: proper fluid level checks!
Tags
capacity, crusher, fill, fluid, location, m21, m22, muncie, plug, rock, saginaw, speed, super, t10, tranny
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
