1974 454 engine bay wiring
Old 08-13-2017, 08:56 PM
bballboy06
bballboy06's Avatar
Default 1974 454 engine bay wiring
I have some connections that i have no idea what they are for. Engine runs fine with no issues currently. Just looking to see if these are needed at all for anything.
1. This wire is up next to the firewall ( Brown, green and black wire)
2. This connection is down next to the alternator
3.This connection is coming out of the firewall ( Pink and Green wire)
4. Connection is long and just one wire comes from centerish of the firewall
5. Connection is right next to the master cylinder
Pictures should be in order as above
Thanks for any help
Old 08-13-2017, 09:58 PM
A C
A C's Avatar
Cruise-In II Veteran
Can't answer for the other ones, but the third pic looks like the backup switch harness which should connect to a switch on the transmission.
Old 08-14-2017, 08:51 PM
bballboy06
bballboy06's Avatar
ttt
Old 08-14-2017, 10:38 PM
Revi
Revi's Avatar
Photo #4 is for the TCS system, there's a single pin switch on the transmission.
Old 08-15-2017, 05:04 PM
vette8121
vette8121's Avatar
#1 TCS Solenoid if the black wire would change color to Blue
#2 Hood door (cowl induction)
#3 Back-up light switch
You have #4
Old 08-15-2017, 05:12 PM
vette8121
vette8121's Avatar
Thanks for any help
Sorry I missed #5, looking at the inside it looks like a headlight warning switch but it's in the wrong place!
To 1974 454 engine bay wiring
Quick Reply: 1974 454 engine bay wiring
