Indian Head Permatex on Freeze Plugs
Old 07-10-2017, 07:44 AM
Burnt71
Burnt71's Avatar
Default Indian Head Permatex on Freeze Plugs
Is it necessary to use a sealer when replacing freeze plugs ? I have always put them in dry ?
Old 07-10-2017, 08:06 AM
PAmotorman
PAmotorman's Avatar
why take a chance of having a leaker.
Old 07-10-2017, 08:32 AM
stingr69
stingr69's Avatar
Received 1,044 Likes on 809 Posts
Always have used Indian Head for that. Why would you not?
Old 07-10-2017, 12:56 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
45 years, I have never used sealer, nor does the factory. I do use brass ones though.
As for sealer. I guess no harm no foul.
Old 07-10-2017, 01:24 PM
BlackC3vette
BlackC3vette's Avatar
Yes, you can put it in dry. But, if it has a slight leak, then you have to go thru the trouble of removing and then re-installing. Of course the engine is back in the car at the time. What the factory did was based on time and cost factor spread out over the production run. So, I don't look at what the factory did or did not do as the holy grail. Freeze out plugs have long been an issue and I found a sealer made by Hercules (Blue Block) that does a great job. Just wear gloves putting it in, the stuff likes to get all over your hands and doesn't like to come off.
Old 07-10-2017, 01:31 PM
dmaxx3500
Support Corvetteforum!
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
sealer is ok,just a little works wonders,,and use a large socket inside the cup and just knock it in
Old 07-10-2017, 03:37 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
in 50 years I have never heard of a freeze plug leaking, because it was installed dry.
But I do use the Brass version, they are softer and conform/seal better, and do not rust.
Old 07-10-2017, 07:56 PM
sunflower 1972
sunflower 1972's Avatar
Old 07-10-2017, 10:23 PM
BlackC3vette
Originally Posted by sunflower 1972
When you get somebody elses workmanship up on your lift, you get to see it all.
Old 07-11-2017, 12:21 PM
7T1vette
7T1vette's Avatar
Received 2,715 Likes on 2,273 Posts
If you have all the original GM parts and the same tooling that was used to install them at the factory, you can install them dry and they will seal. Otherwise, wipe a bit of sealer on them...just for "funsies".
Why take any chance that they might leak.
Most lip seal casings and some cup plugs are treated with a sealing-paint type material on their mating surfaces. That is used as a sealant. If it's good enough for new parts, it should be appropriate for you.
Old 07-11-2017, 12:59 PM
PAmotorman
PAmotorman's Avatar
the holes machined surface could have been scratched when the original expansion plug was removed and the sealer will cover this problem
Old 07-11-2017, 05:39 PM
theandies
theandies's Avatar
Can't hurt.
Old 07-13-2017, 12:51 PM
gungatim
gungatim's Avatar
I've always used a light coat of sealer on the plugs I install. helps lube a bit as it is pressed in and seals any irregularities in the block surface. I imagine brass seal better but I've always used steel. This is how I was taught in auto shop when I was a mechanic. never had a failure that way.
Old 07-13-2017, 04:44 PM
BlackC3vette
Brass plugs are really for marine engines or converting an engine over to marine use. Otherwise, steel is the normal, but brass is nice!
Old 07-13-2017, 05:12 PM
Big2Bird
Big2Bird's Avatar
15 responses on a freeze plug install.
It's like debating paper or plastic.
Old 07-13-2017, 06:10 PM
BlackC3vette
Freeze plugs do not come in either plastic or paper you silly rabbit.
Old 07-16-2017, 05:56 AM
fishslayer143
fishslayer143's Avatar
paper or plastic....
Old 07-16-2017, 06:56 AM
Burnt71
Burnt71's Avatar
Now if I could only find American made freeze plugs
Old 07-16-2017, 10:54 AM
PAmotorman
PAmotorman's Avatar
it is no fun to find out you have a leaker after the engine is in the chassis.
To Indian Head Permatex on Freeze Plugs
Quick Reply: Indian Head Permatex on Freeze Plugs
