Does your factory alarm work or not work? Just curious.
Old 09-28-2002, 11:48 PM
virtue4u
virtue4u's Avatar
Default Does your factory alarm work or not work? Just curious.
I'm only interested in a factory alarm poll, not aftermarket (although aftermarket is probably better).
Old 09-29-2002, 12:28 AM
HawkIVette
Support Corvetteforum!
HawkIVette's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (virtue4u)
Count me for Doesn't work. It did, up until the paint job last year. I just haven't had the time to check out the switches, but when we reassembled to doors and hood, we must have screwed up a switch or two. Hasn't worked since.
Old 09-29-2002, 01:14 AM
Kevin_73
Kevin_73's Avatar
Cruise-In X Veteran
St. Jude Donor '09-'11
The alarm wires were disconnected from the key switch above the liscense plate when I bought my car (and I didn't have a key for it anyway). I removed the key cylinder, dismantled the switch and cleaned the contacts and took the cylinder to a locksmith to have a key made for it. Re-installed everything and hooked it up and it has worked perfectly ever since. :cheers:
Old 09-29-2002, 01:24 AM
RoyArms
RoyArms's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (Kevin_73)
Everything in mine works except the horn :rolleyes: I already replaced it once to fix it before! :crazy: I have big hands and its hard to get at the thing, guess I will be doing it again soon tho :smash:
Old 09-29-2002, 03:43 AM
76Pitter
76Pitter's Avatar
This is my second C3 and both of them have had the same problem. You turn the key for the alarm and it sounds right away. Nature of the beast I guess. I really can't be bothered with it. It's just one extra door-lock in the wrong place as far as I'm concerned. Aftermarket alarms are much better. One thing is for sure. Anyone who still has a working alarm system won't for long.
[Modified by 76Pitter, 2:44 AM 9/29/2002]
Old 09-29-2002, 04:05 AM
BSeery
BSeery's Avatar
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Does your factory alarm work or not work? Just curious. (76Pitter)
Mine did that too. I found the problem to be the pin switches for the T-Tops. At the back of the t-top is a pin that comes out when you lock them into place. That pin is supposed to depress a switch in the car. My t-top pins were not coming out far enought to press the pins.
After a quick adjustment on both sides, the alarm works perfectly now.
Good luck.
Old 09-29-2002, 04:06 AM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
Default Re: Does your factory alarm work or not work? Just curious. (BSeery)
Oh, and on mine it's not a seperate door lock. On the 1980's it's built into the drivers side door lock. Locking from the outside activates the alarm, and unlocking from there turns it off.
It is a pain in the butt when you unlock the passenger side first for the ladies and the alarm goes off. :eek:
Old 09-29-2002, 10:24 AM
TNT
TNT's Avatar
I only voted once but both of my cars, the 69-70 UA6 alarms work! Thad
Old 09-29-2002, 10:55 AM
Paul L
Paul L's Avatar
Yes mine still works. I have a choice between the alarm or this....
Old 09-29-2002, 02:16 PM
drspeedy
drspeedy's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (paul79)
Mine works... it won't shut off, but it works. Good thing the door locks from the inside!
-doc
Old 09-29-2002, 02:23 PM
Rogue Wave
Rogue Wave's Avatar
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
My factory alarms works, but I never use it.
I put in a modern day alarm system. A tad kinder and gentler on the battery. Also, I put electric doorlocks on the car and now have a keyless entry / alarm system. :cheers:
Old 09-29-2002, 03:35 PM
joeveto
joeveto's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I almost wish it didn't work, as it's worthless.
I hate opening the car, only to have the damn thing go off on me. Then everyone around looks at me as if to say "look at that douchebag and his Vette with the crappy alarm going off" while I scramble to turn it off.
Old 09-29-2002, 05:09 PM
rpounds
rpounds's Avatar
Mine works on my '75, such as it is. That squeaky little horn wouldn't even scare off the cat . . .
Old 09-29-2002, 05:17 PM
tangee-vette
tangee-vette's Avatar
Didn't work when I made the purchase of the Vette in 99'...fixed the passenger door switch right away and been working perfectly ever since. I'm not worried about battery run down when I use it. When I'm out and about I never leave it unattended long enough for that to happen. :D
Old 09-29-2002, 05:37 PM
Pete Z
Pete Z's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (tangee-vette)
Mine doesn't work.
Looks like Bubba cutted some wires,but I haven't got the time to look into it.
Most likely I never will..... :rolleyes:
Old 09-29-2002, 06:25 PM
81vette
81vette's Avatar
Doesn't work anymore. Took it out. :D
Mark
Old 09-29-2002, 10:04 PM
rscucan
rscucan's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (Rich's75)
sometimes
To Does your factory alarm work or not work? Just curious.
Old 09-30-2002, 05:56 AM
FinnShark
FinnShark's Avatar
Mine works. Even though I haven't used it much...
Old 09-30-2002, 12:09 PM
73 LS-4
73 LS-4's Avatar
Mine all works except for the drivers side door switch, the switch is stuck in.
:cheers:
Pat Kunz
Old 09-30-2002, 01:46 PM
Sleestak
Sleestak's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (73 LS-4)
Mine doesn't work. I have plans on turning the switch into an ignition cutoff sometime in the future.
Quick Reply: Does your factory alarm work or not work? Just curious.
