Does your factory alarm work or not work? Just curious.
Old 09-30-2002, 02:31 PM
stickboy
stickboy's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (virtue4u)
my alarm works like it's supposed to :cheers:
Old 09-30-2002, 04:47 PM
Chris80
Chris80's Avatar
It may work if I reconnect the wire to the alarm's horn.
Old 09-30-2002, 09:20 PM
kruzzzn
kruzzzn's Avatar
horn works with alarm only ?? :cool: :cool:
Old 09-30-2002, 10:47 PM
loose nut
loose nut's Avatar
On my 79 I had to get into the wiring schematics and found
that buried in the harness there is a diode that is prone to fail.
The diode is in the harness near/behind the stereo.
I used a heavier amp rated diode and never had another problem.
Old 09-30-2002, 11:23 PM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
On mine the key won't turn the lock. Owners' manual says it is the round key.... and it FITS but will not TURN.
I put a Clifford alarm in it ... with Ign Kill of course. :lol:
Old 10-01-2002, 09:45 AM
chucks
chucks's Avatar
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Default Re: Does your factory alarm work or not work? Just curious. (SanDiegoPaul)
Removed the factory alarm and the after market alarm both were a P.I.A. Chuck
Old 10-01-2002, 10:30 AM
vettedan
vettedan's Avatar
My '76 OEM alarm works. I also installed a '95 VAT alarm with my conversion.
Old 10-02-2002, 07:40 AM
thamzid
thamzid's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (vettedan)
My Alarm works like it is supposed to .
Old 10-02-2002, 08:06 AM
Corvette72stingray
Corvette72stingray's Avatar
Mine doesn't work - but I think I am going to get it fixed! :cheers:
Old 10-02-2002, 09:11 AM
hunt4cleanair
hunt4cleanair's Avatar
Yep...two doors, two t-tops and one hood!
Old 10-02-2002, 04:16 PM
JohnS_77
JohnS_77's Avatar
Mine works.
I had to adjust the switch for the hood when I got the car, but it works now.
:cool: :cheers:
Old 10-09-2002, 04:21 PM
HEARTBEATUSA
HEARTBEATUSA's Avatar
Default Re: Does your factory alarm work or not work? Just curious. (JohnS_77)
Nope
Old 10-09-2002, 04:23 PM
  #33
Jvette73
Jvette73's Avatar
Yup ours works
Old 10-09-2002, 06:03 PM
  #34
tim_briz
tim_briz's Avatar
Which box is it in...I would have to find it before I could tell you if it works. :D
Old 10-10-2002, 01:44 AM
  #35
Astro7
Astro7's Avatar
Cruise-In VIII Veteran
Default Re: Does your factory alarm work or not work? Just curious. (tangee-vette)
Are folks having problems with the alarm system running the battery down?
Don't know about the earlier years but my 82's alarm will only go off for about 3 or 4 minutes then shuts off to save the battery. After that the starter interupt will not let you start the car till you reset the alarm. It only happened to me once and had to disconnect the battery to reset the alarm. After that it started fine.
Quick Reply: Does your factory alarm work or not work? Just curious.
