accel super ram
Old 09-28-2002, 02:44 AM
LT1driver
LT1driver's Avatar
Default accel super ram
anyone know anything about this unit, it is a box like fuel injection unit designed by linginfelter for both small and big blocks. Like looks of tripower much better but was thinking of streetability and fuel mileage. It comes with comperter etc. but have to buy program to tune it on laptop. What do you guys think? Thanks. :cheers:
Old 09-28-2002, 10:52 AM
Arkansas Flash
Arkansas Flash's Avatar
Default Re: accel super ram (LT1driver)
I have the Super Ram on my 90 model C4 that I open road race. I also drive the car on the street a lot. I love the system overall. It really lets the motor breathe. You need to go with a complete package though. In other words, if you go with this intake you also need high performance heads and headers, etc.
If you have any questions, just ask.
Old 09-28-2002, 11:40 AM
Corey_68
Corey_68's Avatar
Default Re: accel super ram (Arkansas Flash)
I had one of my '91 C4 (took it off 2 weeks ago to sell). I had the Super ram, 58mm Throttle Body, and accell base. Made HUGE improvments over the anemic TPI. You have to keep in mine the TPI was designed for a 305, and the SR flows twice the air.
Old 09-28-2002, 12:01 PM
69stingray
69stingray's Avatar
Default Re: accel super ram (Corey 68)
Does LPE make a kit for non-fuel injected/non-computer cars? I want to stroke my 350 to 383 one day and I think I want this system! How is the low end torque? I don't drive high RPM very often.
Old 09-28-2002, 12:42 PM
Corey_68
Corey_68's Avatar
Default Re: accel super ram (69stingray)
To my knowledge they do NOT offer a kit for a carb. The torque is unreal!! :eek: A typical 383 would have a 450-480tq and still be emissions and Cali. legal. My Super Ram C4 vert. with 3.73 gears was an ANIMAL on the street. :cheers:
Old 09-28-2002, 02:40 PM
69stingray
69stingray's Avatar
:sad:
:cool:
:crazy:
When is LPE going to get a carb version? Everything thing I have heard about the superRam is very positive!
Old 09-28-2002, 02:45 PM
Monty
Monty's Avatar
I had a SuperRam/DFI 383 in my car before I built the SBC 427. It was a good manifold, amkes tons of torque, and pretty decent hp. The rpm range is limited to around 5800-6000 rpm or so, but for an average built 383, that's plenty. I made almost 500 ft lbs and 450hp+ with that manifold (ported), 10.7 CR, a mech roller cam, and AFR 210 Comp Ported heads. It fits under the stock hood.
Old 09-28-2002, 02:57 PM
69stingray
69stingray's Avatar
Default Re: accel super ram (Monty)
Monty, is there a way to get the SuperRam into a 69 vette?
Your 427 is AWESOME. How you gotten it into the car car and driven it?
Old 09-28-2002, 03:58 PM
Monty
Monty's Avatar
I would assume so. As I mentioned, it fit under my '82 hood, although I did have to remove the air chamber that directed air to the throttle bodies (cross-fire injection). That' shouldn't apply to you '69 obviously.
Thanks, the picture above in my sig is the engine installed in the car. I've put a few hundred miles on it already. The tranny is out right now, I'm building it up with a Transgo Reprogramming kit and high-energy clutches and Kolene steels to handle the power.
To accel super ram
Quick Reply: accel super ram
