Tip of the Day-Th350 Shifter Shaft Seal
Old 09-25-2002, 07:44 PM
Paul L
Paul L's Avatar
Default Tip of the Day-Th350 Shifter Shaft Seal
You can replace the shifter shaft seal ad nauseum if you have a leak. Been there and done it three times. The real problem could be the shifter shaft! The seal can actually score the metal shaft and no re-newing of the seal will make it fluid tight. Does sound a little bizarre that a rubber seal could inflict such damage but apparently so. So replace the shaft. And here is the part number. My tip of today....
[Modified by paul79, 6:46 PM 9/25/2002]
Old 09-25-2002, 07:50 PM
silver 80
silver 80's Avatar
Default Re: Tip of the Day-Th350 Shifter Shaft Seal (paul79)
thanks for the tip paul :cheers:
Old 09-25-2002, 09:17 PM
vettfixr
vettfixr's Avatar
Makes sense. Many a balancer has had a groove worn in it by the timing cover seal. Good tip.
Old 09-25-2002, 09:18 PM
Scott78
Scott78's Avatar
Default Re: Tip of the Day-Th350 Shifter Shaft Seal (silver 80)
Well look it's made in Canada, no wonder it's so soft :lol: :lol:
With the cross border insults aside Thanks for the tip Paul
Scott
Old 09-25-2002, 09:26 PM
Paul L
Paul L's Avatar
Default Re: Tip of the Day-Th350 Shifter Shaft Seal (Scott78)
Scott,
I never thought of that! And some talented person with a sense of humour can answer the question: What do you get when you put together a Canadian-made TH350 shifter shaft with a USA seal? I think I better move this to Off Topic. Or post a pic of my cat ;) .
Old 09-25-2002, 09:31 PM
Scott78
Scott78's Avatar
The funnier answers best left to off topic :lol: :lol:
Scott
Old 09-26-2002, 09:46 AM
virtue4u
virtue4u's Avatar
I agree with you Paul. I just did this job and did notice some wear, but since I did not have the part handy I reinstalled the shaft. So far, no leaks.
To Tip of the Day-Th350 Shifter Shaft Seal
Quick Reply: Tip of the Day-Th350 Shifter Shaft Seal
