Carburator all black inside
I have a 74, L48, 4 speed I am doing a resto on this winter. Finally got under the hood and notice that the Holley List 4777-3, 650 cfm double pumper is all black inside. Its not wet oily black, nor is it soot. I suspect carbon, it will clean off with a brush and carb cleaner.
Other than the black in the carb, the engine runs perfect, instant start, great idle, plenty of power for a L-48. The Edlebrock Performer intake is as clean inside as a new one. The spark plugs are a beautiful tan, PCV is clean and functioning properly.
Any idea what the cause of the black inside the carb might be ?
I bought this Vette late fall last year. Its also possible that someone put this carb on, from another engine in the present black condition....dont know.
8Valve
8Valve
Black inside the venturis, or black in the bowls?
Dementer sole survivor
Received 6,362 Likes
2016 C3 of Year Finalist
since its an unknown to you, i would say clean it and run it and see if it comes back. All I can think is the pcv valve is sucking oil possibly, but you say it isnt oily, so it is weird
I cant do a lot of engine running as we are in deep winter, Vette is on the Kwik Lift and deep snow outside. So any real testing wont come to spring.
With that said, I looked everything over again this morning and have come to this diagnosis;
I believe the Carb came off another engine that was suffering with Back Fires, thus the black carbon. If this black carbon had happened on this engine, then the inside of the Edelbrock Performer intake would also be black, it is as bright and clean as a new intake manifold. Some past owner took this carb off a back firing engine and put it on this engine....thats my best guess. If after a few hundred mile this summer it stays clean, we know this engine was not the problem.
8Valve
What do you attribute the black in your carbs in relating to the big cam ?
8Valve
Gets worse with age of the engine, with worn rings, valves.
8Valve
8Valve
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,928 Likes
This thread is almost 3 years old. Problem is likely moot by now,..
Lars
Lars
