How to get power windows down.. with no power.
As the title states.. I want to pull the body this weekend on my '74 but the strap will put too much pressure on the windows. I need to put the windows down. I'll also be removing the doors at a later time but for now I just need them down.
How can I put them down without power? Can I hook a battery up somewhere and give the switches power?
Been a while since I did the motors but I think you can pull the connector at the motor and find 2 wires. 1 is for up, the other for down. The motor grounds to the door. Hook a battery up to a wire and ground at the motor case.
I think this is right.
Good luck.
Good luck.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
KLUTZ (12-06-2016)
