Need some help with rear suspension/wheel combo
I just installed longer leaf spring bolts from a C4 on the back end of my 78 to be able to lower the back end to a custom ride height. I also installed a new set of 18 inch wheels, and they sit about 3/4" too close to the rear suspension. In order to avoid making contact with the rear leaf spring, I had to tighten the nuts on either side of the leaf spring, raising the back end of the car again (to about stock height). Besides longer studs & a spacer, what options do I have to bring the car back down and avoid the rear leaf spring? I was looking at offset trailing arms, but I'm hoping to avoid pushing the wheels outboard any more, because they are almost perfectly flush with the body right now, and I would like to keep it from protruding. Are the composite leaf springs any narrower than the steel ones? Right now everything is doable, but I would really like to be able to lower the back end again. Thanks so much for the help!
Damon
Damon
C3 of Year Finalist (track prepared) 2019
You can also shorten your spring if you're a masochist like me. Dismantle the spring, cut one end off the main leaf and make a new hole in it, then redrill the centre hole and reassemble. Drilling spring steel is fun, but it's certainly doable. Fair bit of work, but basically free...
Thought I'd post my pm to the OP for the benefit of anyone reading this in future:
Hey mate,
Take the spring apart. Then cut one side of the main leaf (longest leaf), make a new hole, and install the cup that holds the bushing on the bolt. Then drill a new centre hole (again in main leaf only) centred between the 2 spring bolt holes, and reassemble the spring. For the spring bolt hole, I drilled it to ~1/2" from memory, then opened it up to the right size with a carbide burr on my die grinder. There's a bunch of threads on here about doing this, a quick search found this one, but I remember when I was planning to do it that there were others: https://www.corvetteforum.com/forums...ring-pics.html
I haven't got pics of the whole process, but I do have these:
New hole cut next to old hole, spring bolt cup sitting in place:
Modified spring end complete:
Reassembled, clearance to my 17"x9.5" 5.05" backspace wheels:
Hope that helps!
Originally Posted by dgheinen
I've been thinking alot about what you said about shortening a leaf spring. Do you only cut one side, and then offset the center point of the leaf spring? Or do you just cut both sides short and redrill both holes on the sides?
Hope that helps!
C3 of Year Winner (appearance mods) 2019
I don't think that offset trailing arms will change where the wheel is in relationship to the spring anyway.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I believe you can buy a shortened main leaf also to save the effort in modifying the leaf. I should have mentioned - I wouldn't recommend attempting to drill the leaf without a drill press.
resdoggie (11-24-2016)
Metalhead140 (11-24-2016)
Damon
Damon
