Oil recommendation
Oil recommendation
Just got a 76 the other day and im new to corvettes. Think this guy has been sitting for a while. Im planning on draining all the fluids but wanted to start w the oil. Its got 97,000 mi. Was curious on what was recommended for oil and how many quarts it takes. Thanks
5 quarts of any good brand of 10w-30 motor oil. Havoline, Valvoline, Pennzoil, Quakerstate, etc. Also pick up a good brand of oil filter such as AC Delco, Wix, Purolator. Unless the engine has already been running on a synthetic oil, it's probably too soon to switch to it. It would be good to run it a while and check for existing leaks before deciding to use a synthetic.
Oh, and welcome to the Corvette Forum. I believe you will find it a great investment in your Corvette!
Good luck... GUSTO
Good luck... GUSTO
As Gusto said. But I am a fan of "hi mileage" oils. They run a little heavier, and have a better additive package for old engines.
I like to check dipstick calibration too at first oil change. It should be at full mark w/ five qts. And check hot oil pressure too. Gives an indication of motor health, and if a higher viscosity is needed
Piggy backing on the same. I've got a 45K (might be 145K?) mile 75 L48 coupe. I've had it for 2 months. No visible oil leaks and it appears to run consistent oil pressure. I'm a fan of the Valvoline High Mileage oils as well. Would those be ok to use in this car?
Received 1,253 Likes
Hi and Welcome!
For years I used conventional 10-W30, then there was talk that my Corvette needed more zinc so I switched over to VR-1 10-W30 racing oil.
It works fine and O'Reilly sells it by the 6 pack.
Might be a waste of time but I fill up the filter before I put it on.
After you get the new oil in and run it and check for leaks, shut it off and wait a few minutes and read the high of the oil on the stick. That's your FULL mark.
1975Coupe (06-13-2016)
I use the high-mileage dino oil but I also add the Lucas oil stabilizer and ZDP additive to my 74. Let's face it, despite the 21,000 on the odo, the valve seals are still 42 years old. When it sat it would puff just a little on startup. Since adding the Lucas products that has stopped and I swear the ZDP has made the sound smoother.
Please note: If you have a catalytic converter, don't use the zinc. It will likely cause premature failure of your cat.
ZDDP was removed from the oil and Corvette owners felt that the camshaft could wear out faster without the additive and Valvoline 10-W 30 was suggested so I've been using that for years.
https://www.google.com/#q=zddp
Both 100% stock and factory cat. Both with close to 100K miles.
Sold them last year and both passed the California emissions "sniffer" test with ZERO issues.
I had the oil in my 82 with 160,000 miles on the motor changed with Valvoline High Mileage Dexos about 2 weeks ago. First fill up and I went from mid 14 mpg to mid 17 mpg. I think this is accurate, because I put as much fuel in the tank as it will take and religiously re-set the odometer and calculate mpg. Seems like an unreal jump, and will be checking again in about a week. But, it is what it is. Will use that from now on.
1975Coupe (06-14-2016)
Well my vette has no cat. The previous owner replaced the exhaust with a true dual Allens exhaust system that goes straight to two not so quiet mufflers. The thing sounds glorious!
I did notice yesterday that it is eating a small amount of oil on startup and under heavy acceleration. I was thinking about putting in Valvoline's 10W30 High Mileage and adding a ZDDP additive. Good or bad idea?
