Motor Mounts
Old 03-09-2016, 02:04 PM
JLmiller
JLmiller's Avatar
Default Motor Mounts
Thanks for all the great advice, I have another question.
I just rebuild my 1970 convertible 350 to a 383. Should I upgrade my motor mounts?
Old 03-09-2016, 02:31 PM
resdoggie
Had a 1976 L-82, 4-sp
Support Corvetteforum!
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
If they are at all suspect, yes.
JLmiller (03-09-2016)
Old 03-09-2016, 03:02 PM
OzzyTom
OzzyTom's Avatar
I would put solid mounts in, especially if you have a manual trans.
It is the left mount that shears.
If putting in non solid mounts, certainly put the ones with the interlock to prevent excess engine torque lift when it breaks.
Old 03-09-2016, 06:17 PM
toobroketoretire
toobroketoretire's Avatar
I have always used standard motor mounts but with a 3/8" bolt thru the middle of them with a self locking nut to hold the two halves together. That gives the dampening effect of a standard motor mount but prevents the engine from ever lifting up under hard acceleration. Or you can use "locking" motor mounts that have a mechanical stop built into them.
Old 03-09-2016, 07:24 PM
larrywalk
larrywalk's Avatar
I had a left-side solid motor mount develop a 3/4 crack with about 6 months of usage. I'll never go that way again and am sticking to the newer rubber mounts with the safety interlocking feature.
Old 03-09-2016, 07:40 PM
fishslayer143
fishslayer143's Avatar
Use the heavy duty interlocking type mount.. unless you have a boatload of torque,and very sticky tires, you won t break them .
To Motor Mounts
Quick Reply: Motor Mounts
