Borgeson with Flaming River tilt column
Old 03-08-2016, 10:28 PM
71 Vert LS1
71 Vert LS1's Avatar
Default Borgeson with Flaming River tilt column
Is there a thread detailing what is needed to install a Flaming River tilt column on a 71 with previously installed Borgeson steering box?
I'm concerned that if I just order the Flaming River column it will be too long or too short.
Old 03-09-2016, 12:29 AM
1Fordman
1Fordman's Avatar
You need to find out if the Flaming River column is collapsible like an OEM column. I used an Ididit tilt in the 68 and it's not collapsible. Column needs to be approximately 2" shorter which would require some extensive machine work. Would like to run the Borgeson gear box but can't due to the column. 68's only had a telescopic option, no tilt.
Old 03-09-2016, 06:38 AM
Luke in SA
Luke in SA's Avatar
1Fordman, Are you happy with the Ididit column ? I have been thinking about a similar install in my 68, but would also like to run a Borgeson box.
Any pictures of column installed ?
Old 09-19-2016, 09:15 AM
Kris_K
Kris_K's Avatar
Any updates on this as I am interested in this same combo?
To Borgeson with Flaming River tilt column
Quick Reply: Borgeson with Flaming River tilt column
