distributor wrench suggestions wanted
The hold-down clamp and bolt on my 68 convert with stock distributor has the tach drive right in the way where I need to use my distributor wrench. I have the box end type with the off set handle. Even though it is a rather slim box end, it hits the tach drive so it will not go on the bolt. Tightening with the tips of an open end wrench gives poor tightening so the distributor sometimes can turn. I made a 9/16 inch "wrench" from a piece of flat steel and bent it to fit, but it is a poor substitute. Before I heat a perfectly good 9/16 inch open end wrench with my torch and bend it, has anyone found a wrench that works here? I'm thinking a spade foot wrench, but it may be too thick. I already have about six wrenches that I have either cut or ground away to fit on parts on cars I no longer own. Given that this distributor is on thousands of Corvettes, there must be a wrench that fits. Suggestions?
I looked there also. They are all like the wrench I already have. The box end is too thick to fit in the space between the tach drive on the side of the distributor and the bolt that secures the hold-down clamp.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,928 Likes
Pull your distributor out and install it correctly. The tach drive and the hold-down clamp are almost 180 degrees apart: The tach drive should point out towards the driver's side, slightly back. The hold down clamp is on the passenger side, slightly forward. Any wrench will work if you put the distributor into the block the correct way.
Lars
Lars
Lars
Lars
Years ago I had some problem like that and I just bought a allen head bolt
Find out why the proper side hold down isn't working.
If all fails use and allen head bolt as suggested by Gkull.
get rid of the aftermarket chrome hold down. they don't work/fit for nothing. they are pretty universal so not really made for a chevy. can't tell you how many of those thing's I've seen on peoples motors that are reefed down but still don't hold. go back to a stock flat hold-down and you shouldn't have any problems.
Received 1,470 Likes
Cruise-In II Veteran
You need this:
http://shop.advanceautoparts.com/p/a...rm=wrench+sets
You need this:
Here it is at Amazon. I got mine at Summit racing.
Received 4,573 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I have a Snap-On distributor wrench that works perfectly on my 68 Big Block. Nice tool
"get rid of the aftermarket chrome hold down. they don't work/fit for nothing. they are pretty universal so not really made for a chevy."
That is what I plan to do. It does not appear it is long enough to work on the threaded boss on the passenger side (where I tried to use it) and the PO put it on the threaded boss on the driver side, where it does get enough grip but is a PIA to turn with a wrench.
Thanks to the many who gave me suggestions for distributor wrenches. I have had one of the two piece 1/2 and 9/16 inch wrenches for over 30 years. It worked perfectly on distributors from dozens of engines, but this is the first distributor with a tach drive low down on the distrib housing I have worked on- could not figure why it would not work. But- not the wrench's fault. It's the hold-down, dummy!
Wrench
Well, I have no idea if one of these in 9/16 would work on yours, but it works great on mine.
Ignore that this is the metric set....it's the first picture I ran across.
http://www.sears.com/craftsman-7-pc-...&blockType=G41
this is the stock one from Eckler's Corvette Parts for your Vette.
Attachment 47960107
Attachment 47960107
