Q-jet: '80 vs '81 ?
Q-jet: '80 vs '81 ?
Hi,
are there any difference between Q-jet '80 and '81?
I have a chance to get one rebuilt '81 Q-jet that i would use on my '80 C3, and I am wondering if the Q-jet has been changed as a part of L48-->L81?
Corto
Corto
Agree. '80 was the last year for non-computer carb on a 350ci engine in the vette (L48 and L82). Only thing electric on the carb was the electric choke.
I can't speak to the LG4 (305ci) offered only in Kalifornia (sic)...
350ci from 81-85+ (from my memory):
'81 was the computer carb (L81)
'82 & '84 throttle-body injection
'85+ tuned port injection (L98).
The 80 California carb is an E4ME which have slightly different connectors than the 81 E4MEs, but are functionally the same.
If the OP's 1980 is a California car, the 81 carburetor could be used but he would have to switch to newer-style pigtails.
Agreed. An '80 car built for CA would have had the electronic carb. The other 49 states just had the standard Q-Jet in 1980. The '80 CA car and '81 car had the electronic carb that interconnected with the distributor, O2 sensor, and ECU to allow real-time adjustment of timing and fuel ratio. It was an early computer controlled system, but was better than a standard carb (unless tuned well by a knowledgeable mechanic).
qwank (12-30-2015)
