Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-26-2002, 10:33 PM   #1
Ghostrider
CF Senior Member
Ghostrider's Avatar
Default ZZ4 with Rochester QuadraJet carbs!
This may be an old topic, but my 1980 C-3 with ZZ-4 is mated with a 700R4 tranny and still has the old reliable Rochester QuadraJet (model: 17080204-149D-CPM) from the L48 set up. The carb performed badly at the last Dyno test where it ran too lean at about 4,900RMP (short of the rated 5,700 RPM . I only got 260 RWHP when the power curve dropped off with the start of pinging and lean running. I was told that this ol’ type of Rochester was even used on GM 427 or 454 CI engines but with different jets and fuel metering rods. I agree with carb guru: Lars Grimsrud (see Tech Tips) and want to keep my Rochester carb. A local expert also agreed and suggested trying a “couple of jets and fuelling rods”. My question:
Can I hit the nail right on, by immediately installing the correct GM jets and fuel metering rods?
If so what model numbers are they? Who has the correct set up?
Ghostrider is offline   Reply With Quote
Old 08-26-2002, 11:31 PM   #2
Smokehouse69
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Smokehouse69's Avatar
Default Re: ZZ4 with Rochester QuadraJet carbs! (Ghostrider)
You might try emailing Lars or Tom454 directly, either one of those guys know Q-jet tuning and can probably point you in the right direction.
Smokehouse69 is offline   Reply With Quote
Old 08-27-2002, 03:35 AM   #3
theandies
CF Senior Member
theandies's Avatar
Location: "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
I have a Lars rebuild on my ZZ4 and it runs great and very strong up to the 5800 redline. I have never had it dyno'd so I can't give you power numbers but when I get back from Japan (I am on a business trip and will be back in a couple of weeks) I'll check the stampings on my metering rods so you'll have a place to start....if you don't get the informations before I get back. I'd e-mail Lars and tell him you have a ZZ4 and he'll suggest what rods you'll need. I'd also maybe check your carb spacer between the carb and intake manifold. You may have a slight air leak that will cause your lean condition at high RPM's
John
[Modified by theandies, 1:36 AM 8/27/2002]
theandies is offline   Reply With Quote
Old 08-27-2002, 04:56 AM   #4
MIKER
CF Senior Member
MIKER's Avatar
I wish that I had first hand information to share but I don't. I still haven't dialed in my Q-jet. I've pretty much parked it until I can find the time to dial in a few things that need attention on the car.
The answers that I received in the following two posts might provide you with some insight.
Q-Jet rod/jet combo. What are you using? http://forums.corvetteforum.com/zerothread?id=312539
Same question asked in the "Engine Mods" section. http://forums.corvetteforum.com/zerothread?id=312542
Have you read Lars' "How to Tune a Q-Jet" paper? Here's a link to it on Terry Rudy's CorvetteFAQ.com website. http://corvettefaq.com/c3/QJet_Tuning_Paper.doc
and Lars' "Jet Change Chart" http://corvettefaq.com/c3/Jet_Change_Chart.xls
MIKER is offline   Reply With Quote
Old 08-27-2002, 10:27 AM   #5
BeaterShark
CF Senior Member
I don't think there is any *immediate* correct carb setup. If you get it, consider yourself lucky. I would, like mentioned above, email Lars and ask for a starting point. Then, buy some jets and rods just above and below what he recommends. Read his How To on Q-jets and start the trial and error testing.
BeaterShark is offline   Reply With Quote
Old 08-27-2002, 10:48 AM   #6
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
the carb comes with pri jets #71,pri rods # 42, sec rods CH .057 tips i would try CJ sec rods with .040 tips :chevy
[Modified by clem zahrobsky, 9:49 AM 8/27/2002]
clem zahrobsky is offline   Reply With Quote
Old 08-27-2002, 09:58 PM   #7
Ghostrider
CF Senior Member
Ghostrider's Avatar
Default Re: ZZ4 with Rochester QuadraJet carbs! (Smokehouse69)
I did not want to bother him with stupid questions but I did. My problem is that I didn ot have A/F ratios. but here was his answer:
"Ghost -
Hi! Good hearing from you - thanks for the note.
The 1980 Q-Jet is jetted a bit on the lean side for emissions purposes, but can certainly be set up to satisfy your requirements. When you did the dyno run, did you get a printout of your A/F ratio so you know how lean it really was? If you have the numbers, we can see how many percent you're off and re-jet the carb by this percentage. This will get you really close to the ball park on the first re-jet attempt. If you don't have any numbers, I can recommend a combo that will improve your setup, but you'll be in a little bit of a trial-and-error mode. Tag me back with any info...
Lars"
Old 08-27-2002, 10:00 PM   #8
Ghostrider
CF Senior Member
Ghostrider's Avatar
Default Re: ZZ4 with Rochester QuadraJet carbs! (theandies)
I can't wait that long but I will post the results. Thanks anyway.
Old 08-27-2002, 10:03 PM   #9
Ghostrider
CF Senior Member
Ghostrider's Avatar
Default Re: ZZ4 with Rochester QuadraJet carbs! (clem zahrobsky)
This is good info, that I will try, as long as it is for a ZZ4 or equivalent setup.
Old 08-27-2002, 11:04 PM   #10
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
these secondary rods are used in carbs with a open face air cleaner and may even be rich but you are better off to start off rich than lean. if too rich try DA which are .044 dia. :chevy
Old 08-29-2002, 12:06 AM   #11
Ghostrider
CF Senior Member
Ghostrider's Avatar
Thank you all. FYI, here is Lars' final suggestion:
Ghost -
Since you don't have any A/F ratios to play with, we're shooting just a bit in the dark, so any changes made need to be a little bit on the conservative side to keep from "overshooting" the mixture.
The stock jetting on your 17080204 carb is:
71 main jet/42 Primary rod/"CH" sec rod (.057")
This produces cruise and WOT metering areas of:
2.57/3.43 respectively.
As a first step, I would change the primary metering to a 73/44 combination. This will bump your metering areas up to:
2.66/3.65 combination.
This richens you up 3.5% at cruise and 6.4% at WOT. If this makes the engine respond better, and you're headed in the right direction, go to a 75/46 combo. This will put you at: 2.75/3.88
This is a 7% & 13% increase respectively, and should put you solid into the 13:1 range at WOT.
As a final tweak, pull out the "CH" secondary rods and drop in a set of "DA" rods. The DA's are .044" diameter compared to your .057 CH sticks.
This should give you a bit to play with and get you in the ballpark with throttle response and power.
Lars
Reload this Page ZZ4 with Rochester QuadraJet carbs!
Tags
700r4, carb, change, chart, corvette, dyno, lars, metering, primary, qjet, quadrajet, redline, rochester, tune, zz4
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
