Chrome Edge
Chrome Edge
Just received the center grill piece for my 73. The chrome edges looks great! Before I spend a couple of hundred bucks for new left and right grill pieces, is there a cost effective way to dress up the original pieces I still have with a chrome look? I'm guessing no.
Received 3,149 Likes
Received 2,878 Likes
Hi F,
There appear to be abs reproductions of the 73 grills with a 'chrome' edge for about $110. Might those be satisfactory for you?
You might try 'improving' your current grills' edges with the most 'silvery' paint you can find and a tiny brush….and if that doesn't work you could consider the others.
Regards,
Alan
Regards,
Alan
Franks73 (11-06-2015)
Hi F,
Regards,
Alan
Regards,
Alan
I have used this approach on a few other projects. You can get a silver/chrome paint pen and it goes on smooth. Run over it with a clear coat paint pen and it gets nice and shiny. Not quite chrome, but indistinguishable from 5 feet.
I was about to do this with my 73 until I looked closely at the grills. Someone had lightly poof-canned them some time ago. Some 000 and 0000 steel wool and I have brand new looking chrome grill edges once again.
Received 1,470 Likes
Cruise-In II Veteran
Have you considered having your originals replated/restored?
Chrome edge
I bought a set of the reproductions years ago to replace my heavily corroded originals and within 10 years they were disappointing to look at. While they don't corrode like the originals, the chrome fades and the fins take on a somewhat wavy appearance.
Good luck... GUSTO
Franks73 (11-08-2015)
I have the reproduction grilles and they look great (so far anyway). For the price I would be willing to replace them in another 10 years if necessary!
73 Grills are made from pot metal and are prone to pitting.
My originals are fairly pitted, I cleaned them as well as I could, then sprayed them. Did not notice a chrome edge. The new center section I just received is metal, and the chrome looks very nice. Starting to think that if the L and R pieces are this nice, just spend the $$. Why stop now? ChaChing! My car the money pit! I'm sure the pain will recede once I get to drive her!
If you're trying to paint a thin area like the front edges of a grill, shoot them first in the color that is needed. Once that dries, paint the rest of the grill black from the backside. This will keep you from getting black paint on the new (insert paint color here) that you sprayed on the front edges.
Adam
Adam
What about using some chrome pin striping tape? Paint it black and then put the stripes on. You could even fill the pits with filler before paint and striping. Just some thoughts...
Chrome edge.
Hi F,
Regards,
Alan
Regards,
Alan
Hi Frank,
Yes, abs refers to a type of styrene plastic.
I'm out of my league here (73) but from what I read the original grills were cast metal while the reproductions are made of abs.
Perhaps a 73 person will verify!
Regards,
Alan
Regards,
Alan
Chrome edge.
Thanks again for all the input. Mid America has the L and R grill sections with chrome, made out of metal for $100 each. If they are as nice as the center piece I got, they are nice. I might still try to salvage my originals.
Alan (as usual) is correct! My reproduction grilles are plastic and the originals are/were pot metal. The reproductions are very reasonably priced and look the part from 5' away. I have actually had a couple of 73 owners kneel down to have a look at shows because theirs were in bad shape due to corrosion. They are not a NCRS parts, but, fit the bill in the looks department.
