Spark plug heat range
EDIT: Now I'm reading on a different site that a 46 or 47 would be hotter, so much damn conflicting information but it's what I thought...
All my stock headed gen I chevy builds get Bosch Platinum+4 Spark Plugs (short reach peanut plugs) All my aftermarket 3/4 inch get autolite platinums.
The spark jumps off a tiny point easier than those old crappy erosion prone plugs
The 4 tip plugs make it so you don't have to index the plug to get the best flame travel.
Modern plugs last for many years
Most stock cheap plug wires are prone to blow through leakage with HEI ignitions. Just start your car in your garage on a dark night with your hood up. You really need quality wires.
Guys, I have my reasons and this is not a stock motor as I've already said. One or two hear ranges higher is not going to melt my pistons!!! If you can't answer the question then thanks for looking
What you may find is that the R-45 is hard to find, therefore use R-45S.....Perfect for a 1970 LT-1 power...and gap the plugs at .035....otherwise do what you want.....
Use this chart to decide the type you would want.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
For instance a BPR6EY would be a 14mm projected tip resistor plug with a 3/4" reach and a V groove electrode in the heat range of 6. Lower number hotter higher number cooler.
Plenty of reasons to run hotter plugs. Cold weather is one. More heat in the chamber and you still get good burn even when the water does not come up to temp. I go as hot as the engine will tolerate and not detonate.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Be advised that heat range numbers can be opposite in direction depending on the plug manufacturer eg AC heat range goes down in number for colder plugs and NGK goes up in number for colder plugs.
Yes, frustrating sometimes. I use and would recommend NGK as a quality plug. You can get whatever heat range you would like.
Thanks, a real answer with a real solution
Thanks a chart I was looking at on another site seems to say different. As for the recommended heat range, I'd agree if my motor was stock
