Header bolts
Reaching out once more to finish last project of the season.
Want to try to install a stud into the head in hopes the 'inner' threads are still ok. Have hooker sidepipes and the original bolts were small so i think I might have a chance here...
What size stud and threading am I looking for to try this?
Doesnt sound bad now.. But leaking air around that port because of the missing bolt..
I've been using studs with 12pt nuts for years now, but only on the front and rear holes. It's also nice to have the to studs hold the gaskets in place while installing. For all other holes, I use ARP 400-1209, which are 3/8-16 x 1" 12pt with a 5/16 wrench size. I can easily get a wrench on every bolt.
I have 2 studs on the passenger side, one for the AC (typical of R4 compressor equipped C3s) and another at the bolt hole just rear of the #6 primary, used to hold my dipstick in place (Dart SHP 400 block uses 80-85 dipstick placement and slightly different tube).
I have to use 6-point bolts on the bolt holes on the inside of each outer primary (rear of 1,2; forward of 7,8) as the Hedman 68301s slightly crowd the bolt hole. I'm hoping to go to a different set of headers with a bit more engineering added into them, but I have another project taking precedence for the time being...
Also, I use header gaskets, probably because I am not a professional engine builder.
Mr. Gasket has a new exhaust manifold gasket that's made of layered aluminum. It eliminates leaks caused by warped or damaged surfaces and also won't shrink. They say loose bolts from vibration and heat cycling are a thing of the past. After you get your bolt figured out, sounds like these would be the thing for you. Just read the ad in my Oct. '15 Hot Rod magazine. Good luck.
Duane
Duane
#34
ASE- Automotive Service Excellence
FOS- Full Of Sh**
JPC- Just Plain Crazy
#35
The hemis were famous for their ability to breathe. But the big hump on the piston, necessary to fill this void space, screws with the combustion process by messing with the flame propagation.
http://www.hotrod.com/how-to/engine/...n-power-maker/
#39
