454 install
Old 08-07-2015, 04:09 PM
mk8035
mk8035's Avatar
Default 454 install
I have a couple of questions that i thought you guys could help me with. First have a 76 Vette that had a 383 stroker engine total gone. I want to install a 454 into the car. I just changed all the front end parts.
1.Will the engine fit into the car?
2.Will it bolt up to my 350 Trans?
3.Can i use the starter fuel pump and dist fom the old engine?
Old 08-07-2015, 05:02 PM
toobroketoretire
toobroketoretire's Avatar
Yes, the 454" will fit but it'll need some exhaust work to join the manifolds to your existing pipes. And it will bolt to your TH350 although the TH350 won't handle the amount torque a 454" can put out without modifications. The distributor is the same for small blocks and big blocks and I believe the fuel pump is the same. The starter might and might not fit as they are bolt pattern specific.
Old 08-07-2015, 05:17 PM
mk8035
mk8035's Avatar
Thank s a lot. I had the tran totally redone. I think it should work fine.
Old 08-07-2015, 11:52 PM
roger3
roger3's Avatar
Fuel pump is not the same.
Water pump, pulleys, and brackets for alternator and power steering pump etc are different than other GM cars and are specific to the corvette. I have read of people finding setups other than corvette parts that will fit.
Good luck. I put a 468 into my 76 and love it.
Roger
Old 08-08-2015, 07:20 AM
mk8035
mk8035's Avatar
Thanks for the info
Old 08-08-2015, 07:21 AM
John 65
John 65's Avatar
One example would be my 77. No Corvette only, brackets or pulleys. Works well. You should be able to use your stock hood also. Good luck, lots of fun.
Old 08-08-2015, 07:24 AM
waljr
waljr's Avatar
I want to do the same with my 80.
I've been told that you need the dimpled rocker covers
Be sure to post lots of updates
Old 08-08-2015, 07:32 AM
mk8035
mk8035's Avatar
Will do
Old 12-26-2016, 07:43 AM
530planeman
530planeman's Avatar
To 454 install
Quick Reply: 454 install
