Rear interior light stays on
Holley HP EFI w/TPI
Just finished replacing the rear harness on a 1974.
The rear interior light (back of the cargo area) stays on. Seems unaffected by doors being opened or closed.
Any idea why it's stuck on?
Not sure about your year but on a 69, if the hood is open the rear compartment light will be on.
Holley HP EFI w/TPI
Had the same problem on mine once. Turned out to be door jam switch on drivers side was sticking. A little WD fixed it.
Received 1,470 Likes
Cruise-In II Veteran
Have you checked the headlight switch as Biker suggested?
are your forward inside cabin lights on also? or just the rear ?
Caution, many times that rear bulb gets replaced with incorrect bulb.
that bulb should have two contacts on the bottom, not "1 contact"
