this sucker is warpped i tried a heat gun but no
Received 1,470 Likes
Cruise-In II Veteran
(kind of)
I put mine in a steamy shower, got it flexible and used long zip ties to mould it to where I wanted it. I put some ripped up tshirt material under the ties as so they didnt leave a mark in the vinyl covering.
Pulling the rear portion down was the hardest to get right. When it was still flexible I sat it in the sun to dry and put that end down so the weight of the piece help position it.
Not saying it'll work for you, but it worked well enough for my piece.
dodosmike
dodosmike
My t-top panel was warped and hanging down on the inside corner.
I use a flat surface and weight. Then used my wife's steam iron
to shoot steam into the back side board material and let it
set until dry. Came out perfect and the roof panel fits flush with
the center panel now.
Donnie
it worked, pressure cooking my potatoes and the jet stream really soften the compressed board... thanks CF!
Donnie
If its just a small area you need "fixed", An option would be to prop it up somehow over a pot of boiling water. Not sure how your significant other would react to having that part sitting steaming on the kitchen counter. Best do that when she's not home. Do this at your own risk.
how warped is it? mine slightly bows down in the back so you can see it through the back window.
i fooled myself it was not straightened, i had to paint the insides black so it would not be so noticeable...all in all the car is well made, sturdy materials for a 30 + yo car i am impressed
