C3 Power Steering Box Reinforcement from Ridetech
Old 05-22-2015, 05:13 PM
  #81
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Originally Posted by ignatz
No Hydroboost on mine, Steve. Thanks for taking the video..
Too bad you can't see the steering coupler but the different perspective confirms the box is twisting about the horizontal axis rather than the vertical axis (i.e. Pittman arm). And I would say there is quite a bit less movement overall. Hard to tell how much, but what would you say? I guessed 1/4" on mine.
The only time I can really see the dot move when I review my video is when my wife is leaning on the steering locks.
Also, I watched her go through this and thought the same as Smitty mentioned above - I quickly rung through the steering and couldn't see a ton of movement, but my car is on Conti ExtremeContact DWs (300-something treadwear summer tires) on my smooth concrete garage floor - nowhere near the friction that Ignatz and Smitty put through their boxes.
I'd guess <1/8" total travel of the dot. Another unfortunate thing about my perspective is that the dot is closer to the mounting centerline - the view from further out(box input shaft at steering coupler) would see more motion.
Old 05-25-2015, 07:36 PM
  #82
Domobomb
Domobomb's Avatar
How wide and sticky of a tire before this makes a difference?
The 48 hour car was running 315s in front.
Any benefit with my 255 street tires?
Old 05-25-2015, 08:19 PM
  #83
Roadster71
Roadster71's Avatar
Don't know if this was asked in the previous 5 pages of the post, but how is the flexing any different than with a manual steering box?
Old 05-25-2015, 08:46 PM
  #84
danc24
danc24's Avatar
Thought I would post my before and after. Definite reduction in steering box movement.
Before:
After:
Classic Muscle (03-21-2021)
Old 05-26-2015, 02:21 AM
  #85
Bad Bird
Bad Bird's Avatar
Nice. Those results show a marked reduction in box flex for sure.
Old 05-26-2015, 07:36 AM
  #86
Smittys67
Smittys67's Avatar
It is always a benefit to reduce the flex and load on the frame. The bolts have a lot of load on them.
Thanks for the video. I'm not sure I will get one done this week.
Old 05-26-2015, 07:45 AM
  #87
Bad Bird
Bad Bird's Avatar
And when you do get it done, it will be very much appreciated. This thread has turned out to be very interesting!
I wonder how much more the flex would be reduced by subsequently welding up the power steering ram access hole in the frame rail. This hole is probably the weakest part of the frame.
Old 05-26-2015, 11:32 AM
  #88
Shark Racer
Would using the original u-bolts and thick piece of stock make that area a bit stiffer too? And then you avoid a welder...
Old 05-26-2015, 11:28 PM
  #89
Bad Bird
Bad Bird's Avatar
I don't know if you really could brace this big ol' hole with a bolt-on solution:
If you have ever seen a crashed C3's frame, they are always buckled right at this big access hole.
Old 05-27-2015, 01:04 AM
  #90
Shark Racer
Yep... I was brain-dead when I wrote that post.
I was thinking we were talking about the four bolt holes at the bottom. Oops.
I agree - welding is the only way.
Old 05-27-2015, 01:11 AM
  #91
Bad Bird
Bad Bird's Avatar
It's all good. A picture says a thousand words and all that.
I think that a combination of welding up the access hole, running a spreader bar, running the RideTech brace and maybe a thick plate bolted in where the ram attaches would pretty much solve the front end flex. Box the engine mount horns and sway bar attachment points (as per Chevy Power Book) and the chassis might even be half-way decent.
Old 01-22-2016, 01:56 AM
  #92
tristan69
tristan69's Avatar
Before:
After:
Looks good and reduces the movement a lot.
Do you have a Hydroboost as well as I want to see how they work together?
If you have both are you using power steering fluid or Dextron 2 ATF?
Old 01-22-2016, 06:51 AM
  #93
danc24
danc24's Avatar
No hydroboost. Car has manual brakes
Old 01-31-2016, 03:06 AM
  #94
tristan69
tristan69's Avatar
Thanks, I am waiting for Chase to get back to me with where I can buy this bracket and the Burgeon power steering from in Vancouver BC Canada.
I would like to pick up before the CDN $ becomes worthless
Old 02-02-2016, 09:13 AM
  #95
0Rodney@ridetech
Former Vendor
Rodney@ridetech's Avatar
I will remind him if he hasn't already gotten back with you.
Old 03-29-2016, 09:43 AM
  #96
maverickmk
maverickmk's Avatar
i found this thread thru another thread about steering frame issues. I recently found this on my frame (mine is a 1980).
This underneath, it is a complete run.
The power steering belt was removed when I bought this a few years ago. I have been driving it without the power and think this is the result of that. Without the ram's assistance the frame isn't able to withstand the torque of a power steering box alone. I will definitely order this bracket after I weld up this crack. Just me two cents.
Old 04-02-2016, 02:55 AM
  #97
Dirk76
Dirk76's Avatar
High 11s (04-06-2016)
To C3 Power Steering Box Reinforcement from Ridetech
Old 04-07-2016, 02:05 AM
  #98
Zero1Niner
Zero1Niner's Avatar
Hey Maverick,
Are you going to replace the frame? I have big-time frame issues too for my 1981 (that may have been my thread you found). Ive welded up the cracks, now they are reopening, cracking in new places....nightmare.
The Borgeson is certainly making things worse with all the torque its putting on that crappy a$s frame. Most of the new cracks are right where the Borgeson is applying the pressure to the frame wall. Id really like to have one of these tubular aftermarket frames (with C4 or C5 suspension while Im dreaming), but thats way over my budget. Ill be yanking the motor out to have the cracks welded up once again, but Im sure its not permanent, which totally sucks.
I want to investigate doing a partial frame section replacement. I have not looked into that very much yet.
Old 04-07-2016, 02:38 PM
  #99
maverickmk
maverickmk's Avatar
Originally Posted by Zero1Niner
Hey Maverick,
Yes, the long term plan is to find another frame, blast it, reinforce it and paint it. For now I'm just going to weld up this area and run it for a while. I may also weld a plate over the affected area. I will see how it looks after I weld it up. Just need to get some time to get back at it.
Old 04-08-2016, 06:40 PM
  #100
spedaleden
spedaleden's Avatar
Installing mine this weekend
It took like two hours to do. Much easier to do when your putting the steering box in for the first time but not bad.
It is easier if you remove pitman arm which I didn't
Before
After
Quick Reply: C3 Power Steering Box Reinforcement from Ridetech
