Roll bar and cage
Roll bar and cage
Would love to see some pic of people's cars with roll cages or bars and how did you go about installing them?
I have a 1970 coupe that I need to install one in.
Five-point bar in my '69 coupe, welded directly to the frame. I added a crossbar between the rear supports to use as a harness bar, not pictured here.
Optical illusion. They are there, but in the pic you can only see the left side, and it looks like a half-cross bar through the main hoop going to the hoop-diagonal. They extend back through the rear fiberglass and then bend down to the frame on either side of the gas tank. You can see a gusset in the corner where it joins the main hoop. I wanted angled tubes from the hoop to the frame, but this is what I got instead. That's what I get for not learning to do it myself.
Thanks 69autoXr.
Did they install the bars with the body in place? If so how much of a hole did they have to cut out of the fiberglass to get in for welding?
This was around 2002 or so, as such I'll have to guess 4-5" holes as I don't remember exactly.
Body on, gas tank out, I also had all carpet and interior panels pulled as the car was going through a fairly extensive renovation at the time, new windshield frame, body/flares/paint etc.
How did you go about sealing the holes? Did you regales or what?
When I installed the carpet I had to cut it to go around the bars.
Agree, wouldn't install one without the diagnonal through the hoop. Hopefully I never have to test it though!
tight, but everything still fits back there. The birdcage was tied in also
Fuse box was relocated and a vintage air (heater) was used to be able to route the tubes through here. these bolts were temporary
This was all done with the body on so I opted to not do any mount at the kick panel so I wouldnt have to cut a monster hole in the floor to access the frame. Body is off now so Ill be adding one.
Tubing is 1.75x.090 chromo
Very nice. Thanks for sharing. Did you install the stock dash pad when you were done? Did it fit ok other thank having to trim for the bar?
