too much HP.
too much HP.
i have listen to my brothers on this forum and feel i have made a mistake.i built a 408" sbc with all forged short block,AFR 195 heads,1.6 dollar rockers.lunati rollar cam,air gap rpm manifold.labor no object machine shop time no object ,balance to 1 gram,all the best CNC bored and surfaced dead nuts.10.6 compression,.005 deck height.Molodon 7 qt pan,HV pick up and pump.first question; i used Lars ignition timing with empty HEI just a pick up i use MSD to fire.i put rubber band on HEI weights then disconnect vacuum disregard initial timing and take it up to 2500rpm and set at 36 degrees .initial was 23 degrees at 1000 rpm.i feel this is high when connected with vacuum advance it comes out to 54degrees.i put on road -------------ridiculous 3.55 rear with turbo 400 1st gear (700R4 on bench)spins goodyear radial 225/r 15 like i had bicycle tires .i do i calm this monster down! will dangerously break wheels loose in normal passing situation.
i have listen to my brothers on this forum and feel i have made a mistake.i built a 408" sbc with all forged short block,AFR 195 heads,1.6 rollar rockers.lunati rollar cam 510 with 1.6 comes out to 540 lift,air gap rpm manifold.labor no object machine shop time no object ,balance to 1 gram,all the best CNC bored and surfaced dead nuts.10.6 compression,.005 deck height.Molodon 7 qt pan,HV pick up and pump.first question; i used Lars ignition timing with empty HEI just a pick up i use MSD to fire.i put rubber band on HEI weights then disconnect vacuum disregard initial timing and take it up to 2500rpm and set at 36 degrees .initial ended up at 23 degrees at 1000 rpm.i feel this is high when connected with vacuum advance it comes out to 54degrees total.i put on road -------------ridiculous with only a 3.55 rear with turbo 400 (700R4 on bench)spins goodyear radial 225/r 15 like i had bicycle tires .how do i calm this monster down! it will dangerously break wheels loose in normal passing situation.
The rubber band on the HEI weights confuses me. I admit I'm confused easily, but I just don't get that one.
the rubber band around weights ensure there is no vacuum advance what so ever with vacuum disconnected to effect your 36 degree mechanical advance setting.
The weights have nothing to do with vacuum advance, they control mechanical advance only.
Putting a rubber band around the weights will prevent mechanical advance only. Also, I'm not sure I'd leave the rubber band as a permanent solution as it will deteriorate and break after a period of time.
i guess i did not explain myself.the rubber band is put around the weights on distributor shaft ONLY to set timing then it is remove and connect vacuum hose to check TOTAL ADVANCE which consist of initial/mechanical/vacuum. sometimes if you use "gold" very light springs the vacuum with start coming on at idle you what to avoid this.
Get you a set of Nitto 555R drag radials in a 275/60/15, put them on your stock ralley wheel and let it eat.. It will still blow them off from a dead stop but from a 20 mph roll, it will hook on them.
Well, if you're serious, you can do like the factory did in the 70's, and retard the f**k out of the timing. That should make 'er run a little doggy. Not to mention possibly cleaning up emissions a bit. But that's just my take.
I run 275/60R15 M/T on the back of my C3.... It will Break Loose if I put it to the floor. Make cool smoky burn outs into 2nd gear. And If I feather it just right... I can run 10s in the quarter.
But you need to learn to drive it with the extra power... know the limits and stay away from rain and wet roads.
I run MT 295 55 15's to cure that "little problem" you mention. Also am running 36 degrees timing locked out in my 406.
Still have to ease into the throttle from a dead stop, but that hula dance I used to get hitting the gas hard from a 45 mph roll with street tires is gone.
the fear i have is put her to the floor on take off and when it shifts into second the car goes completely side ways out of control on one lane road. Previous to this c-3 i had three 1967 c-2 in a row all big block the conv.was 427-390hp,then coupe 427-435hp then a NCRS 427-400 with 3.70 gears this 408" literally blow the doors off those big block cars in brute torque and instant ability to rev up. you guys hit the nail on the head. i have to some how learn to drive it.my long time friend try to guide me and remove hp (no single plane riser manifold and 600 lift cam with 290/295 at .050 . this is a street only car.besides the insane torque i was surprised the vacuum is 17hg at idle with holley carb adjusted low speed perfectly.one side note those AFR with CNC intake port ,exhaust ports and CC are a work of art.somebody told me they make exact copy of rally wheel in 10" i don't no this to be true.years back i had the unfortunate experience of a 82 collectors edition breaking loose and spinning out of control into a pole with rear tire slamming into pole total the car and left a warning in my brain.the job went smooth took about 5 hours to install because i had to jack front way into the air to put headers in almost vertical to clear steering box and also remove drivers side valve cover.
Because of my driving experience with my 10Z06 and the explosive power from the LS7, when I was planning the rebuild of the L-82 last Spring 2014, I was not concerned with building a monster 355 L-82 or even a 383, since after experiencing 450 RWHP in the Z06 in a much more sophisticated suspension, very light car 3,100 lbs with a MUCH bigger tire on the C6Z06, I was more interested in trying to build a powerful mid range HP/torque L-82 block and components than all out high RPM power. To that end, I too used the AFR heads BUT passed on a higher duration roller cam with more lift (.525/.525, duration 219/225) instead of .550 lift and 225/230+ duration) to create strong mid range torque-its very strong BUT street able. I even reused the L-82 aluminum intake with my Holley 4175 650 CFM vacuum secondary Qjet replacement on the car since 1985 with the stock OEM dual snorkel cold air cleaner assembly. I am going with ARH LTH in the Spring to maximize the exhaust and looking for 450/450 Gross HP/Torque in the end after dialing in everything. The car is only street driven on street tires (although MUCH better tires than 15's-255/45/17 ZR ultra high performance summer only tires). I feel that 350+ RWHP should be perfect for the old C3, not to mention I am not interested in breaking the Super T-10 4 speed, rear diff, halfshafts etc…just me.
