Rear fiberglass spring pics
Well I attacked the the front spring. I cut 1/2 coil off first and that dropped me 1" so I cut another 1/2 coil which gave close to what I wanted 2". It is still Little high on the driver side but I'll drive it this summer and see how it sits in the fall.
Also I tried the 10" bolts today. That's not gona work. The spring ends a down into my tire.
The misses came out and checked it out and she would still like to see the car lower in the back. I agree, what do u guys think. her words when she saw where the spring ends almost contacted the tires were, "That's not gona work, order the new spring". I love it. I can get a VBP at Corvette Depot here in canada but i want to call VBP first to see what they Recommend.
You're married to a smart woman.
If you look at Cboyd spring mount. It looks as if he has a spacer between the spring mount and the diff cover. You can see a half inch gap right behind the bolts as it screws into the cover. This might be his problem. Make sure you don't have the same set up. Longer bolts will work if needed but make sure everything is correct first. My stock 82 sits about 3-4 inches above the tire with 255-60,15 BFG tires. I think the top of the wheel opening was 27-1/2 inch from the ground. Hope this helps.
trw springs are well known to ride stupid high. the VBP spring is Much better and Great People to work with. i have the 360# spring and it rides better than the stock steel spring.
While the fiberglass spring subject is up.. What are you guys running for shocks? I came across a post once with suggested shocks per spring rate, but haven't been able to find it again. I have the vb&p 360 lb. spring in my car.
i have the QA1 non adjustable shocks and they are great. VBP was out of stock and they called QA1 who picked the valving they thought would be best and sent them straight to me in almost no time. the ride and handling is fantastic.
