Which bonding adhesive for metal to fiberglass??
Old 01-07-2013, 01:35 PM
malicatasr
malicatasr's Avatar
I used SEM 39747 Multi-Purpose Panel Adhesive, you have to have to two part mixing gun. It worked great. I just completed the same repair.
Old 12-28-2015, 09:30 PM
r16678
r16678's Avatar
Default 3m part 8609 is listed as bonding Window glass to body
Originally Posted by Stewart's74
Rod,
I rebonded the headlight support using 3M Super Fast Urathane Part# 08609. This stuff is awesome.
I was instructed to use this stuff by a very reputable Vette restorer. He has used it for years with no problems.
You can buy this stuff at any 3M dealer. I got mine at Advance Auto.
Stew
I am going to give the 3M product a try. I noticed is listed for bonding window glass to vehicle body. Is that correct one you used?
Old 12-29-2015, 10:00 PM
AzMotorhead
Support Corvetteforum!
AzMotorhead's Avatar
R16678 The post you referenced is over 13 years old.
Old 12-30-2015, 03:35 PM
r16678
r16678's Avatar
Default Found the West product
Originally Posted by wydglydrydr
I recently did this same project. I had the rivet pops on the front end of my 72 I wanted gone. When I put it back together, I used West Six10. It's a 2 part mix that comes in a single tube just like standard caulk. It's mixed as it's dispensed. West sells a caulk gun designed for this tube, but you can make it work with a standard caulking gun. You just have to convince the tube to go into the gun. One tube was more than enough to do the header bar, cost me about $20, and I'm thrilled with it.
Found the west product, will try
Quick Reply: Which bonding adhesive for metal to fiberglass??
